1999 Chevy Blazer Codes
Old Jun 23, 2025 | 09:38 PM
Walka's Avatar
Walka is on a distinguished road
Default 1999 Chevy Blazer Codes
I just pulled these codes from my blazer this afternoon where do I start? I just bought this car and it’s got a small electrical leach so it has a negative terminal switch that I can disconnect, aswell I found and replaced some dry rotted vacuum lines by the brake booster running to the intake manifold please lmk where I should start
P0106
P0112
P0113
P0117
P0118
P0121
P0131
P0132
P0133
P0134
P0135
P0143
P0144
P0146
P0147
P0151
P0152
P0153
P0154
P0155
P0171
P0172
P0174
P0175
P0300
P0325
P0327
P0401
P0404
P0420
P0440
P0442
P0446
P0461
P0500
P0601
P0603
P0604
P0605
P0704
P1133
P1134
P1153
P1154
P1441
U1026
U1042
U1192
U1193
C0265
C0237
C0226
Old Jun 23, 2025 | 09:55 PM
lexblaze's Avatar
lexblaze will become famous soon enough
Without knowing the history . And Since you have a list of the codes, with that extensive list I would start with clearing them and do a full test drive cycle and see which ,if any, come back. Without disconnecting battery first . That will give a possible starting point .
With that many and variety of codes possibilities could include : loose/ bad wiring at PCM , bad ground connection somewhere , simply related to ground disconect switch , to failing (unlikely if runs semi ok ) PCM . But clearing and see which come back could help narrow down actual possibilities
Also note any performances issues you seem to notice ?
Then work on parasitic drain on battery issue
Catecean Damnation
Oct 31, 2018 08:48 AM
kcurry02
Dec 12, 2013 08:56 PM
95vortec4.3
Aug 16, 2013 06:57 AM
moe111
Apr 24, 2011 11:10 PM
Takz
Feb 17, 2010 05:16 PM
