1999 GMC Jimmy won't start without starting fluid...
1999 GMC Jimmy 4x4 - 4 door - 4.3l - 195,XXX miles
So I've been reading through massive amounts of threads via the "Search" function, but wanted to get everyone's opinion before I drop the tank and put in a new fuel pump.
Here is the issue:
Here is the issue:
- Car will not start without using starting fluid.
- Once I use starting fluid the vehicle will start up and will remain running (only in park, haven't attempted to drive out of the garage).
- While running I can slowly accelerate without the engine stalling, but once I try to accelerate aggressively the engine will stall. After it stalls I would have to use more starting fluid to restart the engine.
- Fuel Filter
- Fuel Pressure Regulator
- Throttle Position Sensor
Following this flow chart will determine the problem, then no "opinion" will be necessary, it will be a "fact" what the problem is
https://blazerforum.com/forum/tech-a...agnosis-23038/
JESSEDG
Mar 21, 2014 12:36 PM
blazintammy
Dec 5, 2013 08:32 PM
lukeawilliamson
15
Apr 4, 2012 05:26 PM
kearney99
Jul 27, 2011 10:24 PM
