1st blazer need help!
1995 blazer 2 dr auto.
i have several problems i need help with.
1st is the problem with the blinkers, they dont work, hazards work tho. (ive posted in the other topic about it)
also when i push the brakes the right turn signal lights up(along with the right turn signal in the dash)
i also have a plug that i have no idea where it plugs in, its on the passenger side, comes from the front(or around from the other side) the wires are green and black(just 2 wires) any idea?
and also the windshield washer motors dont seem to work (both front and rear) and i didnt see a fuse listed on the panel for it.
and are there any fuses under the hood?
on the 95 is there supposed to be a ECU mounted on top of the coolant reservoir?
im hoping i can turn this $1,000 truck into a decent truck.
thanks everyone
Kevin
thanks everyone
Kevin
Could you snap a picture of that plug and post it?
As far as the blinker, locate the flasher modules (under the dash) and replace the turn signal flasher relay. If that does not work, then the multifunction switch is the likely cause. It is by far cheaper to try the flasher relay first though.
I would disconnect the electrical connection at the windshield washer pump and test for voltage when you have the switch in washer mode. I am not sure where the fuse for the washer pumps is located off the top of my head...
ill get that picture tomorrow. and ill see about changing that relay.
another issue is that when i lift the drivers handle(when locked or not) the light dont come on, but it does if i lift the passenger handle. is there a sensor or something in there?
and i cant open open the glass from the outside, but the inside switch works fine.
thanks
Kevin
thanks
Kevin
1000.00 bucks? for a truck with all those problems? how many miles are on it just wondering because i payed 400 for mine with 100k miles, everything works great beside it needs a new tranny and has little idling problems and window motors
191,xxx but finding something that ran, or didnt need alot of body work was kinda hard. plus this has a/c and heat which my current DD doesnt have.
i like it so far, just some grimlins to work out.
Thanks
Kevin
Thanks
Kevin
well i took a pic of it, but my sis-in-law cant find the cable to the camera. but i will post it when i can.
the wires runs up under the battery.
thanks
kevin
thanks
kevin
CrashOverride
09-24-2010 12:56 AM
BlazinAtlanta
05-23-2010 02:42 AM
spaceapex
32
01-18-2010 09:08 PM
