2000 4.3 intake to injector assembly vacuum leak help!
please and thank you for all your help!
Ok so I got my dad’s ZR2 completed and running with my new motor I gave him. Brand new everything, AC Delco updated spider injector assembly.
Here’s my issue
So when I goose the throttle where the injector assembly comes thru the upper intake the assembly pushes up into the upper plenum and I can hear a vacuum whistle. I’m sure the movement isn’t supposed to happen so I’ve done no chemical spraying to prove that’s my vacuum leak cause I don’t want a giant mess on my new motor. can anyone give me some tips to get that to stop preferably without pulling the entire upper intake .
Please and Thank you all for the help!!
Here’s my issue
Buttefly plates often whistle due to air going past the sharp plate edges. Personally I dont recall vacuum leaks causing whistle. A small burst of carb or brake cleaner spray ( petroleum solvents) will show a leak because the spray is combustible- the idle speed should jump. The sprays wont leave residue in small amounts.
the whole electric plug and what the fuel lines connect to go up in the air when you step on the gas removing the engines vacuum. It’s like the vacuum is pulling the part of the injector assembly that goes thru the upper intake.
So I believe I have actually determined that it’s the throttle body sucking air. I forgot about it but I did cut off that goofy thing on the throttle body butterfly.
Ok so I do have the updated injectors, and I just found a link below my post for this issue. Maybe I’m wrong and I do have a problem at my injector block that goes thru intake.
BearandJamie
Aug 4, 2015 08:12 AM
2000jimmbo4x4
Mar 29, 2012 08:45 PM
kaynos
13
Aug 3, 2011 01:13 PM
