2000 4dr 4wd... How do i get Keyless entry on my truck?
i have the ls model. i wanted to get keyless entry on it. it look like it might have had it before. i just bought this truck and would like the convenience of just pressing a button to unlock it. doesnt have to be original keyless. any suggestions?
I did OEM keyless on my Blazer. You need a donor BCM with keyless entry, the airbag module from same donor truck, and matching RKE modules. I documented my experience on here. Do a search for RKE and me as the author.
Do you know for a fact it doesn't have the remote keyless entry from the factory? I just ask because I recently purchased a 98 Tahoe & when it didn't come with the remotes I just thought it didn't have the factory keyless entry when in fact it did.
On your Blazer check on the label in the glove compartment & see if it lists "AU0" as one of the option codes. If it does, it has the factory keyless entry & all you would need is a remote. Ebay is a good place for used remotes.
I couldn't remember the RPO code. That's how I ID'd the donor truck.
Bonsee
04-19-2011 08:03 PM
ronaldo
05-16-2008 04:39 AM
