2000 4x4 Chevy Blazer Alternator Replacement
Old Jan 7, 2015 | 08:55 AM
AlexS's Avatar
AlexS is on a distinguished road
Hey all, so I'm sorry for the extremely delayed response. Got the alternator changed with the right one, couldn't see the number anymore since it was so old so I just got a guy to bring the two different kinds out and got the right one. Unfortunately my belt noise came back after a day of driving. I'll make a new post about that as it is really annoying and I'm kinda tired of throwing money at it and not fixing it (although the alternator was obviously bad, sounded like I had sand in trying to turn it freely).
Old Jan 7, 2015 | 09:21 AM
newguy's Avatar
This belt will fix it, guarenteed
Amazon.com: Goodyear 4060970 Gatorback Poly-V Belts: Automotive Amazon.com: Goodyear 4060970 Gatorback Poly-V Belts: Automotive
make sure you order the right belt for your truck
Old Feb 17, 2015 | 12:04 PM
jimspahr@msn.com's Avatar
Default Why did the squealing go away?
Newguy, is the GdYr Gatorback you listed going to fix the squeal because of the gatorback design or the 1" longer size. I had read a post in this thread by 'Burned' that the AD 244 required a one inch longer belt. Is that particular GdYr Gatorback a one inch longer than stock belt?
Per Burned:
'Putting in a AD244 with a 1" longer belt is a better idea. That squealing is the alternator.'
Old Feb 17, 2015 | 12:39 PM
newguy's Avatar
gator back design stops the squeal. like I said, make sure you get the right size for your application. Ad244 is an inch longer.
Old Feb 18, 2015 | 08:25 AM
Rock Auto catalog is the only place I have seen that shows the length of the belt. I can imagine going into an Auto Zone or Advance Auto store and asking for a belt one inch longer than stock. Does NAPA have that kind of info? Where can you get that info?
Old Feb 18, 2015 | 08:42 AM
burned's Avatar
burned is on a distinguished road
I wasn't recommending a belt for getting rid of the noise. The AD244 alternator requires a 1" longer belt because it sits higher than the stock alt.
The noise could be coming from a bearing. It could be the idler pulley, AC compressor, water pump....etc. Get a piece of garden hose and have a listen at all the things the belt comes in contact with.
Old Feb 18, 2015 | 05:35 PM
newguy's Avatar
put baby powder on it while its running if the squeal goes away , its the belt
justblazin1
Nov 17, 2013 12:53 AM
Joop Gisbers
Dec 28, 2012 10:53 AM
piperarrow
Oct 6, 2012 03:53 PM
JWhis
16
Aug 27, 2012 01:03 PM
zantam06
Aug 4, 2012 02:00 AM
