2000 blazer 4.3
Old May 5, 2010 | 03:40 PM
mudderrob's Avatar
mudderrob is on a distinguished road
Default 2000 blazer 4.3
I was driving down road and blazer shut off,will not run.Something is telling the injectors not to work.Changed fuel pump, filter , reg, got 62 psi. Fuel pump relay good. If I down gas down intake it will run.Changed PCM,ICM, Crank senor,coil,MAP senor.Help what is left.
Old May 5, 2010 | 07:24 PM
You have verified that it is a fuel supply problem by determining that it will run by pouring fuel down the throttle body.
Any codes? Why did you replace all of those components?
Old May 5, 2010 | 08:08 PM
mudderrob's Avatar
poured fuel down the throttle body,runs until gas gone then dies. throwing code P1351.replaced all those parts trying to get it to run.
Old May 5, 2010 | 08:39 PM
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
JODYM
Feb 2, 2009 07:53 PM
lionel2
Apr 16, 2008 04:45 PM
