2000 blazer 4.3
Old Sep 5, 2012 | 10:39 PM
pappy57's Avatar
pappy57 is on a distinguished road
Default 2000 blazer 4.3
just done rebuilt heads distributor,plugs ,plug wires,cap, rotor bug, coil, ignition module, and a crank sensor i still get no spark from any plug wires what the hell is going on.? I've also reset the timming with the bug pointing at the 6 on the distributor ready to burn the damn thing.
Rick
Old Sep 5, 2012 | 11:20 PM
Rottidog's Avatar
If you replace the crank position sensor you have to get a re-learn done on it. Most shops with a better grade scanner can do that.
Old Sep 6, 2012 | 12:36 AM
50lb_cat's Avatar
+1, and hopefully you used delco or delphi parts or you will be replacing the ignition componets again...
Old Sep 6, 2012 | 06:44 AM
pappy57's Avatar
Default ****
well i thought i would be done with this thing a relearn what is that ive worked on cars for over 40 years and never heard of this stuff before i changed the crank sensor it still wasnt giving me any spark from the coil what could cause that?
Old Sep 6, 2012 | 10:41 PM
pappy57's Avatar
Default help
so just what is a relearn and can i do it myself?
Old Sep 6, 2012 | 10:51 PM
FsTFwRd's Avatar
A re-learn? Isn't that some kind of pass-lock security feature Government Motors (GM) started putting on their 03+ vehicles? Cause I didn't think I had this on my 2k.
Old Sep 6, 2012 | 11:10 PM
Rottidog's Avatar
It takes a higher end OBDII scanner/communicator that most decent shops will have. They have to hook up to the OBDII port & run the vehicle/PCM through a re-learn procedure.
Here are a couple Google results
Crankshaft Position Sensor Learn Issues on Gen III Engines
GM Computer Relearn Procedure (including Crankshaft relearn)
If you replace the CKP it is necessary.
Old Sep 8, 2012 | 07:23 PM
pappy57's Avatar
;ve taken everything back apart use paint stripper to make sure grounds where good ,Replaced the computer ,crank position sensor ,ignition module,coil,plugs, plug wires, distributor cap ,and bug,even ran it up on number one and made sure the bug pointed at the 6 on the distributor,and the mark on the ballancer was dead on the v shape on the front pan Still no spark i put an in line spark plug tester on number one plug no spark any ideas im about ready to burn all i had to do was head gaskets nothin has ever happened where iv got no spark ????
Old Sep 11, 2012 | 02:22 PM
FsTFwRd's Avatar
Have you tried what Rottidog said? I'm not sure about this now, but if the processor in the computer you installed needs to be programmed, I'm betting you need a dealer to do that. I don't know why but you know how these car companies always recommend you take to a dealer. Try putting the old computer back in also.
My friend has a camaro and a few years ago he changed his stereo out for an aftermarket one. His car wouldn't start after this and he had to take it to a dealer to get some theft lock situation worked out with the new radio.
Old Sep 12, 2012 | 05:15 PM
pappy57's Avatar
That makes sense i guess since i have the radio with inop flashing im waiting on my new ecm now then ill take it to don brown chevy for a freash flash
