2000 blazer 4 wheel drive problems
Old Jan 25, 2013 | 03:42 PM
drnwoody's Avatar
drnwoody is on a distinguished road
Default 2000 blazer 4 wheel drive problems
Hello new member here and i have a problem my blazer seems like its ingaged but not pulling with front tires. When i have it on jacks and ingaged tires turn different ways so i beleave its locked in but when i put it on the ground tires dont pull i sure could use some help. I can pull cable and feel it engage drop the drivers tire back on the ground and trun the rh front tire its stiff but truns like its slipping
Old Jan 25, 2013 | 11:58 PM
3 button or 4 button Auto? Raise the right front wheel off the ground. Engine at idle, transmissin in park, select 4HI. The right front wheel should not rotate by hand. If it does, the clutch in the right front axle tube is not engaging the axle shaft with the front differential. Check the electro vacuum switch mounted on the firewall: At idle, one line must have manifold vacuum, the other line must have vacuum in 4WD only.
Old Jan 26, 2013 | 07:33 AM
drnwoody's Avatar
I have the 4 button ,, Thank you captian i will try this and post back.
Old Jan 26, 2013 | 12:50 PM
drnwoody's Avatar
Well captain i did what you said and i can rotate the front tire by hand i also have vacum at the switch I think i have some big problems. Thinking about putting a match to it. again thanks for the help.
Old Jan 26, 2013 | 01:20 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Check your vacuum actuator under the battery tray, it should have vacuum at the hose with 4wd selected. No vacuum in 2wd. Also make sure that the cable going to the diff is not seized up.
Old Jan 26, 2013 | 02:36 PM
drnwoody's Avatar
Okay i have vacum at the actuator, cable moves, i can hear it engage all the lights work, no service lights, if i put it on jacks and engage front tires turn one forward and one backward but when i put the drivers side back on the ground i can still turn the rh tire its a little stiff but it will turn, then if i take it for drive it sure is not in 4 wheel drive but light says it is. No clicking or clunking, seems smooth, Im lost.
Old Jan 26, 2013 | 05:38 PM
If the actuator cable is pulling in when you select 4WD, but the RF wheel still rotates, the axle clutch is not engaging the axle with the differential. The RF axle tube must be removed and disassembled to diagnose why the clutch isn't working.
mirrorimij
Jun 8, 2019 03:34 PM
twenty4sux
Apr 23, 2013 09:02 PM
laser770
Jan 21, 2013 01:36 AM
necropenetrator
Jul 28, 2012 04:11 PM
lizzj70
Jun 23, 2010 06:57 PM
