2005 - pcv don't rattle, can see right through it?
Old Jan 22, 2013 | 09:26 PM
Dustyrandall's Avatar
Dustyrandall is on a distinguished road
Default 2005 - pcv don't rattle, can see right through it?
Trying to finish tuning up, I pulled out the pcv valve and it's hallow? Is this normal for a 2005 4x4 LS, manual says it should rattle but there is no plunger or anything inside to rattle this one and the whole is like a pencil lead wide? it's clean and came out easy i'm confused, please someone help me out with this? Is there another place were I have to clean instead really want to clean it but I don't know what to clean, or replace help!
Old Jan 22, 2013 | 10:59 PM
Manatee's Avatar
Manatee is on a distinguished road
Get a new one they are cheap.
Old Jan 26, 2013 | 05:33 PM
But do I get one with a plunger or does another part of the vacum system in the 05 models already manage the airflow?
Old Jan 26, 2013 | 05:39 PM
4x4blazerguy's Avatar
Take your part to a real parts house & see what is called for. Are you sure you took out the PCV?
Old Jan 26, 2013 | 05:42 PM
PCV's were changed at some point from being a valve to being a controlled leakage orifice so it makes sense that you can see right through it if you have the later design.
Old Jan 26, 2013 | 06:28 PM
rexazz2's Avatar
rattle is a myth
it is a spring and weight
if it is sludged up it may not be working properly
Like said above ,just replace they are cheap
meatbag
Sep 24, 2012 10:26 PM
96jimmyslt4x4
Jul 18, 2011 10:08 PM
ohsofly
Jan 4, 2011 09:01 PM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
2005Jimmy
Feb 12, 2010 02:28 PM
