2000 blazer
Old Jan 1, 2013 | 06:49 PM
shortie2bluved's Avatar
shortie2bluved is on a distinguished road
Default 2000 blazer
I have a 2000 blazer the lifter needed to be replaced i disconnected battery after hooked the battery back up an the security light was flashing wit battery light. when I jumped in it to turn the key i got nothing not even a click. the lights we t out. now i have no power to dash. I charged the battery no help
Old Jan 2, 2013 | 09:51 PM
blown262's Avatar
blown262 is on a distinguished road
I had a similar problem when I did the manifold gasket on one of mine. Did you check the back of the alternator? IIRC, there should be 2 red wires with eyelets that bolt to the output bolt of the alternator. If the nut is only hand tight, you will get power until you try anything, then it will disconnect. Hope this helps
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
JODYM
Feb 2, 2009 07:53 PM
lionel2
Apr 16, 2008 04:45 PM
