2000 Blazer
Old Jan 22, 2016 | 09:04 AM
dodge man 1969's Avatar
dodge man 1969 is on a distinguished road
Default 2000 Blazer
I've got a 2000 chevy Blazer 4.3. I've replaced fuel pump, fuel filter, plugs,wires,cap,button,distributor,the spider fuel injection system, ignition switch,and key. Everytime I try to start engine it will crank and die, crank and die. But as long as I'm pouring gas in it it will run perfect. I've checked everything there is to check and all is good. Fuel pressure good, firing great, what could cause it not to run on its own.
Old Jan 23, 2016 | 08:01 AM
Welcome to the forum!
What could cause it not to run on its own? With symptoms like you describe, Passlock is the first place to check.
Does the "Security" light in the instrument cluster illuminate when you initially turn the ignition to the "RUN" position, (before you attempt to start the engine)? After a few seconds, does it shut off, flash, or remain illuminated?
Here's something to try:
Apply battery voltage to the fuel pump prime
terminal in the underhood fuse panel.
The fuel pump must activate and remain running.
Attempt to start the engine.
Post your results.
jello219
Sep 3, 2019 05:19 PM
HailSusy90
Headers, Intake, & Exhaust
Sep 6, 2015 06:02 PM
01Blaze218
Oct 13, 2011 10:05 AM
JODYM
Feb 2, 2009 07:53 PM
lionel2
Apr 16, 2008 04:45 PM
