2000 Blazer ABS light
Old Aug 28, 2013 | 05:49 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
UPDATE: the grinding issue i was experiencing was the new sensor making contact with the reluctor ring inside the hub. i backed the bolt out and the grinding went away but now ABS light went back on when im moving. i looked and it seems the passenger side has a shim in it while driver side does not. do i need this shim? i would like to avoid buying a new hub just to solve an abs sensor issue, but i suppose if i need it i need it. is there anything i can use as a shim or set the air gap?
Old Aug 28, 2013 | 06:40 PM
The first sentence in post #7 explains. The sensor contacted the tone ring and most likely destroyed it. The shims are selected and installed when the hub is manufactured, each one is different.
Old Aug 29, 2013 | 10:57 AM
Chip's Avatar
Chip is on a distinguished road
I took mine in to get the ABS fault codes read and found that the problem was in the left wheel sensor. Before I took it in I sprayed de-greaser between the back of the brake rotor and the dust covers on both sides hoping that the sensor(s) were just dirty. As it turned out, after the fault code was cleared the warning light in the dash went out and has not returned. (yet) Time will tell if I am that lucky...I also found out that on my 95 the sensor is mounted in the dust cover and not in the hub.
Old Aug 29, 2013 | 01:26 PM
bigred01's Avatar
bigred01 is on a distinguished road
I wouldn't worry about it I unplugged my hub sensors because abs is garbage, the pedal feels more natural without it.
Old Aug 29, 2013 | 02:33 PM
sky_blazer's Avatar
i feel everything should work as it was made to. while some say abs is garbage, others say it saves lives, as far as i go i am neutral on the whole matter. i just want everything to work as it should. besides if i sell the truck the next owner may want working abs.
Old Aug 29, 2013 | 02:39 PM
sky_blazer's Avatar
UPDATE: i just broke down and removed both hubs and gonna replace them and call it done upon further investigation i think the passenger side was bad anyway which could have been the root cause of my light, now im stuck with these stupid sensors though. Carquest sucks, they wont return them cause they were on the vehicle even 10 minutes or 10 yrs it doesn't matter. thats what i like about Autozone, they would have taken them back and i would have 120 in my pocket and have new hubs ordered. damn you Carquest. on that note anybody looking for an ABS sensor? one good one made contact with reluctor ring but not long, probably still work
Old Aug 30, 2013 | 08:14 PM
sky_blazer's Avatar
UPDATE: 2 new hubs with sensors ordered and on the way, keeping fingers crossed this fixes the problem. i have spent way more then i budgeted for the truck in first place. if it does not fix it im either gonna pull bulb in the dash or take it in to get scanned
Old Aug 31, 2013 | 08:14 PM
sky_blazer's Avatar
new hubs installed, took for a ride and have not seen light. seems my problem is solved "fingers crossed"
Old Aug 31, 2013 | 08:32 PM
As mentioned earlier, ABS does a self test on each start up: no light, no problems. Good job, glad you got her fixed.
Old Sep 1, 2013 | 07:40 AM
sky_blazer's Avatar
thanks, could not have done it without your help.
