2000 Blazer hard to start in morning
Old May 22, 2009 | 09:59 PM
bking_27's Avatar
bking_27 is on a distinguished road
Default 2000 Blazer hard to start in morning
Hey there, I just recently bought a 2000 blazer with 95,000 miles on it. Its 4x4, 4.3l, 5sp. But its starting to get a little hard to start, esp after sitting for awhile. I had a CEL a few days ago which was P0174/P0102. I took the MAF apart and cleaned it up. Light went out the next day and truck runs better. But like i said sometimes its just hard to start, I turn the key, hear the pump whine for 2 secs then stop. I did buy a pressure tester, When i turn the key and it does the 2 sec prime, it builds up about 54psi, i start then idle its about the same. Then i drove it and while i was giving it gas it would go up to 60psi. Also when i shut it off it goes up to 60psi, and i kept an eye on it, and it does leak pressure down but pretty slowly (5 psi in 10 mins or so)
Like i said before, i can hear the pump whining and the car runs pretty good (does have a slight hesitation when stepping on the gas) but i hear the pump whining even when the truck is running. Does this sound like a fuel pump about to go? I just replaced the fuel filter today, see if it helps at all. THANKS FOR ANY HELP!!!!
Old May 23, 2009 | 12:03 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
possible fuel injection spider unit
Old May 23, 2009 | 02:17 PM
54PSI is low, it should be 60+psi prior to turning over the engine. This could be the possible cause of your hard start condition. When was the last time you replaced the fuel filter?
Old May 24, 2009 | 02:08 AM
bking_27's Avatar
i replaced the fuel filter just before taking those fuel pressure readings. So I got a new pump today. Figured it was getting weak. Hopefully everything will be squared away after that!!
Old May 24, 2009 | 04:27 PM
Let us know how it goes.
Catfish9
Jul 26, 2014 10:57 AM
drillbit taylor
Feb 19, 2010 10:52 AM
atombob
22
Jan 3, 2010 12:09 PM
whipskipper
Sep 12, 2008 07:23 PM
davidmd
Nov 26, 2006 12:47 AM
