1999 Blazer 4x4
Old May 24, 2009 | 04:51 PM
roger136913's Avatar
roger136913 is on a distinguished road
Default 1999 Blazer 4x4
Truck died the other day.... Since then I took off the out line from the fuel filter and turned the key and gas shot out...
I check all fuses, replaced the distrib cap and rotor, coil is getting spark, alt and battery replaced also and same thing... I turn the key and the engine turns but won't start. With the distrib cap off I turned the key and rotor turned so the timing belt is fine...
Anyone have any ideas??? I am thiniking it might be the fuel pressure reg??
Old May 24, 2009 | 05:31 PM
With fuel, pressure is where it's at, not just flow. This needs to be checked with a fuel pressure gauge at the fuel pressure test port up on the engine. 60+psi is required. I would suspect a fuel supply problem. Test the pressure and let us know.
kamilkowalski
Apr 30, 2015 08:36 PM
Tinted
35
Feb 7, 2011 01:12 PM
scott_wheels
Mar 6, 2010 04:37 PM
soundmasterx
Jan 21, 2010 10:24 PM
Heffty
Engine & Internal
Mar 27, 2007 03:02 PM
