2000 blazer loss of power
Old Nov 18, 2009 | 09:44 AM
Snap a picture. It should be behind the large catalytic converter and may be just out of sight.
Old Nov 18, 2009 | 03:28 PM
Wesley96LT's Avatar
Wesley96LT is on a distinguished road
DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
<A href="#ss1-554109">Circuit Description
The heated oxygen sensor (HO2S) is a sensor designed to create a voltage relative to the oxygen content in the engine exhaust stream. The control module supplies the HO2S with signal high and low circuits. Ignition voltage and ground are supplied to the HO2S heater by independent circuits. The oxygen content of the exhaust indicates when the engine is operating lean or rich. When the HO2S detects that the engine is operating rich, the signal voltage is high, and decreases the signal voltage as the engine runs leaner. This oscillation above and below the bias voltage, sometimes referred to as activity or switching, can be monitored with the HO2S signal voltage.
The HO2S contains a heater that is necessary in order to quickly warm the sensor to operating temperature. The heater also maintains the operating temperature during extended idle conditions. The HO2S needs to be at a high temperature in order to produce a voltage. When the HO2S reaches operating temperature, the control module monitors the HO2S bias, or reference, voltage. It also monitors the HO2S signal voltage for Closed Loop fuel control. During normal Closed Loop fuel control operation, the control module will add fuel, or enrich the mixture, when the HO2S detects a lean exhaust content. The control module will subtract fuel, or "lean-out" the mixture, when the HO2S detects a rich exhaust condition.
Certain vehicle models utilize an oxygen sensor behind the catalytic converter in order to monitor catalyst efficiency.
This diagnostic trouble code (DTC) determines if the HO2S is functioning properly. It checks for an adequate number of HO2S voltage transitions above and below the bias range of 300-600 mV. This DTC sets when the vehicle control module (VCM) fails to detect a minimum number of voltage transitions above and below the bias range during the test period. Possible causes of this DTC are:
• An open or a short to voltage on either the HO2S signal or HO2S low circuits
• A malfunctioning HO2S
• A problem in the HO2S heater or its circuit
• A faulty HO2S ground
This DTC is designed to detect an HO2S voltage that remains at a low (lean) voltage for more than a specified number of seconds during the test conditions. This DTC is set under the following conditions:
• There is an HO2S circuit fault that results in a false lean exhaust condition.
• The HO2S is correctly detecting a lean air/fuel ratio resulting from either a vacuum leak or a fuel control system fault.
<A href="#ss2-554109">Conditions for Running the DTC
• No active TP sensor DTCs
• No active EVAP DTCs
• No active IAT sensor DTCs
• No active MAP sensor DTCs
• No active ECT sensor DTCs
• No active MAF sensor DTCs
• No active misfire DTCs
• No intrusive test in progress
• No device controls active
• The system voltage is between 11.7-18 volts.
here is a electrical layout picture.
The number below refer to the step number on the diagnostic table.
  1. Monitor the HO2S voltage of the opposite bank sensor. If the voltage activity of the opposite bank sensor is similar to the voltage activity of the suspect sensor check for lean conditions that may affect both cylinder banks. An opposite bank sensor with normal HO2S voltage activity indicates the suspect HO2S needs replacement or a lean condition exists only on the suspect HO2S cylinder bank.
Step
Action
Values
Yes
No
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
  1. Run the engine until normal operating temperature is reached.
  2. Use the scan tool in order to monitor the HO2S voltage for the sensor that applies to this DTC.
Is the HO2S voltage fixed less than the value specified?
86 mv
Go to Step 4
Go to Step 3
This DTC is intermittent.
Are any additional DTCs stored?
Go to applicable DTC
Go to Diagnostic Aids
  1. Turn OFF the ignition.
  2. Disconnect the HO2S connector for the sensor that applies to this DTC.
  3. Jumper the HO2S LOW circuit terminal (Engine harness side) to a known good ground.
  4. Turn ON the ignition, with the engine OFF.
  5. Use the scan tool in order to monitor the HO2S voltage for the sensor that applies to this DTC.
Is the HO2S voltage within the specified value range?
351-551 mV
Go to Step 5
Go to Step 6
  1. The HO2S may be detecting a lean exhaust condition. Check for one of the following conditions:
    HO2S connector water intrusion
    An exhaust leak between the HO2S and the engine
    Vacuum leaks
    Incorrect fuel pressure
    Lean fuel injectors
    An inaccurate MAF sensor
  2. Repair any of the above or similar engine conditions as necessary.
Did you find a problem?
Go to Step 10
Go to Step 8
  2. Remove the jumper from the HO2S LOW circuit terminal.
  3. Disconnect the VCM connector that contains the HO2S HIGH signal circuit.
  4. Use a DMM in order to measure and record the resistance between the HO2S HIGH signal circuit and ground.
  5. Measure and record the resistance between the HO2S HIGH signal circuit and the HO2S LOW circuit.
Is the resistance at the specified value on both tests?
Go to Step 9
Go to Step 7
Repair the HO2S signal HIGH circuit shorted to ground or shorted to the HO2S LOW circuit. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 10
Replace the HO2S. Refer to Heated Oxygen Sensor Replacement .
Go to Step 10
Important: The replacement VCM must be programmed.
Replace the VCM. Refer to VCM Replacement/Programming .
Go to Step 10
  1. Use the scan tool in order to Clear the DTCs.
  2. Start the engine.
  3. Allow the engine to idle until the engine reaches normal operating temperature.
  4. Select the DTC and the Specific DTC function.
  5. Enter the DTC number which was set.
  6. Operate the vehicle within the Conditions for Setting this DTC, until the scan tool indicates the diagnostic Ran.
Does the scan tool indicate that this diagnostic Ran and Passed?
Go to Step 11
Go to Step 2
Does the scan tool display any additional undiagnosed DTCs?
System OK
all this information is from the GM data base for service and repair i have access to this from the dealer i work at so i dont have a problem giving you the information. enjoy. pm if you need any more charts.
Last edited by swartlkk; Nov 18, 2009 at 03:34 PM. Reason: Combining consecutive posts. Please use the edit feature to add additional information to your post if another member has yet to reply.
Old Nov 18, 2009 | 03:34 PM
You must have missed my first reply to this thread where I posted the identical information.
Old Jan 15, 2010 | 09:17 PM
rob2129us's Avatar
rob2129us is an unknown quantity at this point
Default still nothing
I have since replaced both o2 sensors with n ot luck. I then removed the o2 sensor in front of the cat still the same. Tonight i put a fuel pressure guage on itAt about 55-56pis it would start then drop to about 50 if reved a little it would dropdown as low as 40 and stall out. Tried to start again was at about 55 psi started dropped and stalled. What should the psi be while running and also being brought up to a high idle say 2500. thanks
Old Jan 16, 2010 | 01:51 PM
offroadwnc's Avatar
offroadwnc is on a distinguished road
we had a s-10 that did exactly that. Turned out to be the fuel pump
Old May 3, 2012 | 01:50 PM
Ironbox's Avatar
Ironbox is on a distinguished road
Default p0151
i got p0151 and replaced the o2 sensor and the code came back any ideas?
Old May 3, 2012 | 01:52 PM
Diagnosing the issue would be a good place to start. Just throwing parts at a problem can get expensive.
Old May 3, 2012 | 01:55 PM
Ironbox's Avatar
I agree just not sure where to start, i just had the spider replaced and plugs and all that stuff, just not sure where else to look
Old May 3, 2012 | 01:56 PM
The links at the top of this thread provide the diagnostic procedure from start to end that will get to the root cause of the problem.
Old May 3, 2012 | 01:59 PM
Ironbox's Avatar
thanks will work on it
Mskitty8556
Mar 6, 2014 08:56 PM
bryanmine
May 19, 2011 11:27 AM
AnAirbagSavedMyLife
Jan 21, 2010 11:23 AM
BrianSw
73
Sep 6, 2009 09:16 PM
ryn9909
Jul 21, 2008 05:01 PM
