-   -   2000 Blazer LS sunroof wont close (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/2000-blazer-ls-sunroof-wont-close-93018/)
Philip Mildren Aug 12, 2016 09:42 AM
Started this thread because the older threads have dead links.
The sunroof opened partially, closed it partially, and then opened it fully. The shade and glass are both recessed into the roof with the shade being further in than the glass. When I hit to open button, there is a sound from under/above the driver side visor, as if a relay is tripping. When I hit the close button, no sound. Either way, there is no movement from the sunroof.
From this, I am making a few assumptions. The fuse is good, but there maybe an issue with the relay? That or the glass has come off track or something else that Im not really sure of.
Came here looking for guidance, links on how to remove the roof liner to gain access to the sunroof motor, or maybe a trick/tip to keep from having to remove the roof liner.
Thanks in advance.
LesMyer Aug 12, 2016 12:49 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024142
LesMyer Aug 12, 2016 12:50 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024219
LesMyer Aug 12, 2016 12:57 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024627
LesMyer Aug 12, 2016 12:59 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024753
LesMyer Aug 12, 2016 01:00 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024818
LesMyer Aug 12, 2016 01:01 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024873
LesMyer Aug 12, 2016 01:02 PM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1471024923
LesMyer Aug 12, 2016 01:06 PM
Or you could just jumper the motor, run it closed, and forget about it!!
LesMyer Aug 12, 2016 01:10 PM
Thanks in advance.
See step 5 on post#5 and also any necessary subsequent steps if you just want to run it closed without removing the headliner.
