2000 blazer makes howling noise when driving
Old Mar 26, 2010 | 01:59 PM
jlm1122's Avatar
jlm1122 is on a distinguished road
Default 2000 blazer makes howling noise when driving
noise gets louder when vehicle is slowing down and ends as a click click click when coming to a complete stop. Noise quits if I put it in 4wd. Tried changing cv shaft and wheel bearing. Any other suggestions?
Old Mar 26, 2010 | 05:51 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Check the oils in your transfer case, rear end, and front end. Sounds like a bad pinion bearing or in the transfer case. Start by finding out if something is parched and needs lube.
Old Mar 26, 2010 | 07:51 PM
Old Mar 29, 2010 | 02:43 PM
jlm1122's Avatar
I don't know if these issues are related but now the ABS light comes on each time I start driving it also??? Thank you for the suggestions so far. We'll take a look and check the oils or see if anything needs to be greased.
BlazinHo
May 11, 2014 06:09 PM
cwikk
Dec 10, 2013 08:03 PM
Irish07
Oct 31, 2012 06:04 PM
Sk8er
Mar 6, 2008 09:43 PM
cliro
16
Dec 10, 2007 01:20 PM
