2000 Blazer need to tighten front end load new Torsion keys and bars?
Old Sep 12, 2012 | 11:58 AM
spider21's Avatar
spider21 is on a distinguished road
Default 2000 Blazer need to tighten front end load new Torsion keys and bars?
Is their a heavy duty torsion key or bar you can put on a 2000 blazer. My front end is weak and I have a poly plow on it. I always crank up my torsion bars when I put the plow on but they need a little more stiffness. The truck has 115k miles and could be weak in the bars or keys?
Old Sep 12, 2012 | 12:08 PM
rexmburns's Avatar
Super Moderator
Find yourself a set of zr2 bars and swap those in there. They are way beefier and alot of people swap them on their trucks just for that reason. Should be a good way to go to give you the extra support you need for the added weight of the plow. You should post up some pics with the plow on there don't see that to often!
Old Sep 12, 2012 | 12:13 PM
spider21's Avatar
I am also thinking of putting on Timbren bump stops but I just cant understand how once the plow is on I will be riding on these bumpstops. Not just bouncing off them but actually riding on them. That has to cause major vibration and who knows what other problems. I have a meyers 6.5 poly plow which is the correct blade for a lightweight truck.
Old Sep 12, 2012 | 12:55 PM
rexmburns's Avatar
Super Moderator
Yeah I would say you would want to keep the front off the bumpstops. If you search around you can fnd the zr2 bars fairly cheap. They are a direct bolt in with no modification required. I would reccomend and alignment when you install them is all.
Old Sep 12, 2012 | 02:20 PM
50lb_cat's Avatar
I would also look into heavy duty shocks if you don't have them already.
Old Sep 12, 2012 | 02:52 PM
rexmburns's Avatar
Super Moderator
x2 I forgot all about those silly things lol!!
Old Sep 13, 2012 | 12:57 PM
grizzstang's Avatar
grizzstang is on a distinguished road
They are designed for that purpose. They are bigger than the factory bumpstops. I have a set on the rear of my truck for towing and they work well with no vibration or problems of any kind.
Duram98jimmy4x4
Suspension Tech
Mar 19, 2011 07:18 PM
Moores12345
Lifting Tech
23
Jan 6, 2011 04:36 PM
papacope
Jan 28, 2010 06:21 PM
98blazr
May 5, 2009 09:30 AM
