2000 blazer rear brake help
Old Aug 25, 2007 | 01:27 PM
FGD's Avatar
FGD
FGD is an unknown quantity at this point
Default 2000 blazer rear brake help
2000 Blazer 4WD
I have the rear calipers removed, but I can't get the rotor off...Shouldn't it just slide off? Is there something to do with the parking brakes holding it on? How do I remove it? Please help.
Thanks,
Old Aug 25, 2007 | 05:24 PM
Default RE: 2000 blazer rear brake help
There is an internal parking brake. Mostlikely, the inner drum has rusted behind the parking brake shoes. It's going to be fun to get them off... I know mine were a royal pain when I replaced the rear brakes on my old Bravada.
Old Aug 25, 2007 | 08:46 PM
Hanr3's Avatar
Yes there are inner parking brakes. The vest way to get them off is to tap the drum witha hammer while you pull the drum out. Each tap will release the brakes enough to let the drum slide some. No doubt you will have to work at least two sides of the drum, this can take some time. Bring a beer.
Are you sure the drum is free fromt eh hub face? Does it move around and the studs don't? If the drum and studs turn at the same time and or you know its till stuck tot eh axle you need a hammer. I prefer a ballpeen hammer and use the peen end. Pound between the lug studs. If your aim isn't perfect put your lug nuts on the studs to protec the threads. You want to pound betweent he studs on the drum. Hit it hard, your not going ot break it, what you are trying to break is the rust bond the drum has with the hub face. You'll know when its free, the tone of the hits wil change from solid to tingy and thte drum will move around. Then use the back and forth method I outlined above.
I highly recommend you use anti-sieze on the hub face, drum face (where wheel makes contact), and each lug stud.
Old Aug 26, 2007 | 09:43 AM
FGD's Avatar
FGD
Thanks for the suggestions. I got them free. Basically it was exactly what all of you suggested, it was rusted to the centre hub. A little Release All and some hammering with the aid of some beer. Got it loose. I could definatly hear the change in tone from a ping to a solid thunk when if finally boke loose.
Thanks again for the help.
Old Aug 26, 2007 | 03:01 PM
Hanr3's Avatar
your welcome, glad you got her done.
madblazerowner
19
Mar 2, 2012 12:43 PM
bill737
Jun 24, 2011 04:24 PM
00PewterGMC
Sep 27, 2010 06:16 PM
00Blazer1
Apr 30, 2009 07:05 AM
mlon01
Sep 7, 2007 11:48 AM
