2000 blazer, running like crap
Old Oct 3, 2011 | 11:52 AM
Duggerrocks's Avatar
Duggerrocks is on a distinguished road
Default 2000 blazer, running like crap
replaced fuel pump,rotor&distributor cap,plugs, wires, intake gasket, its still hessitating badly, im told they all do it at some point, i just need to get it fixed. any ideas?
Old Oct 3, 2011 | 11:53 AM
xgiovannix12's Avatar
Proper fuel diagnosis better then guessing wasting all your money
https://blazerforum.com/forum/tech-a...agnosis-23038/
what brand parts did you use also
Old Oct 4, 2011 | 06:06 AM
Default crap
ac delco fuel pump, because the GM pump i bought 3 years ago was dying, the plugs etc was all highly recommended as well by numerous professionals and i dont recall at this point the brands
Old Oct 4, 2011 | 09:46 AM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
did you check for vacuum leaks?
Old Oct 4, 2011 | 09:55 AM
Mike98Blazer's Avatar
What he said ^^^^^
The spider injection on these is known for causing all kinds of crap when they wear out. Diagnose fuel system first.
Old Oct 5, 2011 | 07:03 AM
going monday to be put on the computer again, thanks for the input, i will post more when i know more and i am taking notes.
Old Oct 5, 2011 | 10:16 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
My blazer has the timing chain tensioner issue. Fools the knock sensor into forcing the computer to retard timing. I was able to verify this with only a live data stream. You may want to consider this.
Old Oct 5, 2011 | 11:51 PM
FsTFwRd's Avatar
"They all do it at some point" is fixable! My 2000 ran like hell for almost 3 years, no service engine light or anything. I was afraid to pull out in front of traffic, had no power to pass anyone etc. I'm not sure when your blazer is 'running like crap, you could be a little more specific. But, before you go blowing a bunch of cash, try cleaning the Mass Air Flow, assuming you haven't done it.. below it the step-by-step link.
Click this: https://blazerforum.com/forum/tech-a...leaning-40420/
It wont hurt to look at the EGR either
Click this: https://blazerforum.com/forum/articl...leaning-40424/
Old Oct 6, 2011 | 06:29 AM
thanks, .....still taking notes, what you and everyone else has described is very accurate
Old Oct 6, 2011 | 09:20 AM
xltaylor's Avatar
xltaylor is on a distinguished road
take a business card and cut out a washer to fit between the crank shaft sensor and timing cover to shim the sensor out a little and see if it helps, cured my problem.
