2000 blazer sport utility upper noise and runs rough.
Old Jan 12, 2015 | 04:25 PM
  #21
^^^ Good advice right there! All of it! ^^^
Old Jan 13, 2015 | 10:49 PM
  #22
ooseven's Avatar
ooseven is on a distinguished road
Well I think I have bad news. Pressure check is 60 psi and only 3 psi lose. And stays just below 60 psi cranking. So I take it it is blown. Unless some one has some other idea.
I made an add on craigslist and got an reply today:
HELLO IM GREG FROM GIAUTO PARTS I CAN GET YOU A MOTOR WITH 80,000 MILES FOR 450 DOLLARS AND THAT ALSO INCLUDES SHIPPING TO YOUR LOCATION AND HAS A 90 DAY WARRANTY IF INTERESTED LET ME KNOW OK AND TY.
GIAUTOPARTS
Does anybody hear of this guy? Sounds like a good price I believe.
Waiting for response.
Old Jan 13, 2015 | 11:48 PM
  #23
ooseven's Avatar
OK here something. I had my son change oil the other day. But I just added 1 gal. Just to flush it out and to lower the oil sense it was so much in there. It did smoothen it it out some. But did not show on dip stick. I just had him check it again, still does not show on dip stick. I know it takes 5 qts but 4 qts should show on the dip stick Yes/No?
Old Jan 14, 2015 | 02:57 PM
  #24
ooseven's Avatar
And just had him take the dip stick out and it smells like gas big time. Now what? Head gasket? If fuel pressure good and holding mmmmmm
Old Jan 14, 2015 | 03:01 PM
  #25
ooseven's Avatar
And just had him take the dip stick out and it smells like gas big time. Now what? Head gasket? Fuel pressure good and holding mmmmmm
Old Jan 14, 2015 | 03:10 PM
  #26
Head gasket will not cause that. Check the link in post #5.
Old Jan 14, 2015 | 03:31 PM
  #27
ooseven's Avatar
Now there is no pressure. Can hear the fuel I believe engaging in there. Will not even move the needle. I'm going to take the intake off. Must be in there.
Old Jan 14, 2015 | 03:33 PM
  #28
Follow the steps in this link and it will take you to the problem: https://blazerforum.com/forum/2nd-ge...eakdown-88305/
Old Jan 14, 2015 | 04:01 PM
  #29
ooseven's Avatar
Done this last night. Had 60 psi and leaked 5, 56 psi cranking. Now it has no pressure at all. None zero. Smell a lot of gas on oil stick. I'm digging down to the spider. Has to be there less the pump decided to give out. But I hear something around the spider area when activating the fuel pump.
P.S.
I did read through post five link. That is why this post is being made. Pressure last night none today.
Old Jan 14, 2015 | 04:17 PM
  #30
Nowhere in the link does it mention checking pressure while cranking. All pressure readings are taken with the key on, and the engine off.
When the pump activates, you should hear the fuel rushing through the pressure regulator, which is inside the plenum.
