2000 blazer still hesitates
my 2000 blazer still hesitates like its not getting fuel or air. if i put my foot in it. it will bog down then take off. plus it has a little "hicup" at highway speeds. here is a list of things i have changed, plugs, wires, rotor, tps, fuel pump, filter, cleaned maf sensor, it starts and idles fine, any help would be appreciated, as you can see it is getting pretty pricey.
I had similar problems about a year ago, and pretty much replaced the same stuff you did. I would recommend getting a scan tool or finding a scan tool that shows "live Data". Watch your fuel trims while running and see if you get readings like -33 in my case. If that's the case do an aftermarket MFI injector swap. Also make sure your EGR isn't stuck open. I would also recommend checking your O2 sensors, but those are pretty good about throwing a SES light if they are bad.
try spraying some carb cleaner around the intake gaskets, also try removing the oil cap while the engine is running and see if it stalls out. Sometimes if the intake gaskets are leaking really bad it will stall. Or remove the pcv valve and breather tube on the passenger side and induce small amounts of propane while watching fuel trim on the scan tool. Also check for vacuum leaks around vacuum lines especially near the pcv
justblazin1
10-21-2013 09:16 PM
DAVEHILLIKER
14
06-08-2011 07:59 AM
robbi_carter
04-30-2010 10:15 AM
