2000 Blazer Window Help
Old May 18, 2008 | 11:36 AM
ronaldo's Avatar
ronaldo is an unknown quantity at this point
Default 2000 Blazer Window Help
I have a 2000 Blazer with the drivers side window that won't work. I thought the motor was bad because it had power at the motor, but the motor wouldn't lower the window.
I drilled through the gear and put a bolt in it, released the tension on the spring. When I drilled out the rivets on the motor, I found the motor would operate properly.
After placing a piece of wood inside the door to keep the window from dropping, it appears that something is jambed because after I removed the bolt in the regulator gear (everything still apart) the window is still jammed in the up position.
I drilled out the 4 regulator rivets to see if I could get something loose and this is where I am stuck. The rivets are out, but I can't disconnect the regulator from the lift device.
How does this go together? I tried to do a search, but no luck. Every thing I read says drill out the 4 rivets and remove. How does it remove?
Any Help would be great.
Old May 18, 2008 | 03:00 PM
ronaldo's Avatar
Default RE: 2000 Blazer Window Help. One Way
Well, I didn't get the regulator off, but I did swing it aroung enough to get the rivets out.
Didn't have a rivet tool, so I put it together with 1/4 pan head bolts. I ground the tops flat andused locktite on the nuts. It should hold until together until I can do it right. If I ever do it right.
Old May 26, 2008 | 06:43 PM
Hanr3's Avatar
Replacement motors come with nuts and bolts.
Next time you work on the window I find that a couple strips of duct tape over the top ot the door and attached to both side of the window will hold the window in the up position.
e602
91
Mar 8, 2015 04:53 PM
GolfClapperX
Jun 5, 2009 03:48 PM
Valafar
Mar 30, 2009 07:49 AM
stingra65
Jul 25, 2007 07:52 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
