2000 Blazer won't start - has fuel pres-new cap & rotor
Old Feb 13, 2012 | 01:04 PM
AutomagicLS1's Avatar
AutomagicLS1 is an unknown quantity at this point
Default 2000 Blazer won't start - has fuel pres-new cap & rotor
My 2000 blazer fired right up last night when I moved it. It snowed here last night and this morning it wouldnt fire at all. I verified fuel pressure ~60psi while cranking. Tried starting it with help of a battery charger. I thought maybe some moisture got to the cap and rotor so I replaced both. Still won't start. Any ideas guys? Thanks
Old Feb 13, 2012 | 06:02 PM
Is the distributor cap wired correctly?
Do you have good blue, (not orange) spark at each plug while cranking?
Will the engine try to start with a shot of carb cleaner?
Key ON, engine OFF, fuel pump running: fuel pressure must be 60psi to 66psi and must remain above 55psi for 10 minutes after the pump shuts off.
Old Feb 13, 2012 | 07:04 PM
pettyfog's Avatar
That was warm front precip wasnt it?
When your underhood parts are sweating and your plug wires are older and it doesnt start, first place to look.
Cap, rotor, wires,, wipe down coil tower.
Funny how those things become second nature.. first thing I look for on a no-start after precip .. ESPECIALLY warm-front precip.
Old Feb 14, 2012 | 10:44 AM
Well I got it started jumping it with my diesel. The cap and rotor that were in there was in pretty bad shape it still had the factory GM sticker on the cap and i've got 165K on my blazer. My only guess is the plugs possibly got fouled when it wouldn't start yesterday morning and thats why I had so much trouble getting it going. I let it sit over night and it started right up this morning in the cold.
Old Feb 14, 2012 | 02:30 PM
spittybays
Guest
Posts: n/a
Know when you have a damp night go out in the dark and start, then look for any sparks.
Old Feb 14, 2012 | 03:43 PM
In the future if it happens to flood, hold the throttle to the floor while cranking. This shuts off the injectors until it starts.
Bagherra
Mar 1, 2015 05:28 PM
floridatide
Jun 24, 2011 05:35 PM
JPinCanada
Feb 27, 2011 01:00 PM
LRV31
Oct 29, 2010 06:00 AM
dirtbagger
Feb 25, 2009 07:51 AM
