Rotor & cap question
Old Feb 28, 2015 | 09:51 AM
Bagherra's Avatar
Bagherra is on a distinguished road
Default Rotor & cap question
If u just replace the cap, rotor and wires, is there a special procedure required afterwards i.e. cam re-learn etc?
Thanx!
Old Feb 28, 2015 | 10:59 AM
newguy's Avatar
no there is not
troubles
Old Feb 28, 2015 | 11:25 AM
Bagherra's Avatar
cool!!
only gotta be worried about re learn if you remove the distributor correct?
thanx!!
Old Feb 28, 2015 | 03:14 PM
newguy's Avatar
no, actually it think it only if you mess with the crankshaft position sensor
Old Mar 1, 2015 | 12:59 PM
Camshaft retard needs to be checked/adjusted if the distributor hold down bolt is loosened.
Crankshaft position sensor relearn is only necessary if you move, remove, replace or disturb the sensor, or the timing cover, (or replace the PCM).
Both require a higher end scan tool. Code readers, and most hand helds, are not capable of accessing the necessary data streams.
Old Mar 1, 2015 | 02:01 PM
newguy's Avatar
Thanks captain
Old Mar 1, 2015 | 05:28 PM
Bagherra's Avatar
kool!!
Thanx Cap'n
AutomagicLS1
Feb 14, 2012 03:43 PM
JPinCanada
Feb 27, 2011 01:00 PM
LRV31
Oct 29, 2010 06:00 AM
urbex
Jan 10, 2010 10:47 PM
kornphlake
Aug 11, 2006 05:55 AM
