2000 Bravada - sluggish/surging acceleration
2000 Bravada, approx 90,000 miles. Very sluggish acceleration, started out as an intermittent issue, but last day or 2 it's been constant. To the point now where I have to hold it to the floor to maintain 40mph on a flat road. Also, it wont hold a constant RPM under constant throttle - it's a cycle of cutting off and surging. Another thing I noticed, which may or may not mean anything - above 5000 rpm, the volt gauge drops quite a bit and the AC stops running cold.
Ran the codes, and got the following:
P0101
P0131
P0143
P0151
P0300
Researched the codes and it appears it could be a myriad of issues from plugs/wires, to O2 and airflow sensors.
Any input as to the most likely culprit(s) will be greatly appreciated.
Thank you!
P0101
P0131
P0143
P0151
P0300
Thank you!
P0101 - Mass Air Flow System Performance
P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1
P0143 - HO2S Circuit Low Voltage Bank 1 Sensor 3
P0151 - HO2S Circuit Low Voltage Bank 2 Sensor 1
P030x - Random/Multiple Cylinder Misfire Detected
I would look into the power & ground supply for the HO2S sensors from the PCM as defined in the wiring diagrams in the linked to diagnostic threads. A PCM ground issue could cause the MAF & HO2S sensor codes and general poor performance. Look over the diagnostic threads for common diagnostic points.
Researched on here and found that the PCM is grounded to the firewall by the brake booster (G117). Checked that out and it's tight and clean as a whistle.
Anything else easy to check before I wave the surrender flag?
kennyking927
Aug 29, 2014 12:17 AM
tlmatney
Jun 17, 2009 06:16 PM
03, 2000, acceleration, blazer, bravada, cheverolet, forum, intermittently, p0131, p0143, p0151, s10, sluggish, surges, surging
