2000 chevy blazer
If you want a diagnostics approach and have a scanner:
Any codes?
What are your fuel trims?
Do the fuel pressure leak down test in the sticky
If you want the parts cannon:
Flooring it over rides the oxygen sensor closed loop fuel control loop and commands a rich fuel mixture so you likely have a fuel delivery issue. Candidates for replacement are fuel pump, regulator, upstream oxygen sensors, injector spider, fuel filter.
Let me know which way you want to go.
George
Any codes?
George
Welcome to the forum. I hope that you find the help you need to get your truck running well.
You're in good hands with George helping to troubleshoot. Be sure to follow suggestions and respond with details on what you find.
Caroline Picard
Apr 12, 2011 03:30 PM
