2000 chevy blazer 4x4 LT 4.3l hesitates
Old Oct 17, 2013 | 10:59 PM
justblazin1's Avatar
justblazin1 is on a distinguished road
Default 2000 chevy blazer 4x4 LT 4.3l hesitates
at a dead stop or a low rolling speed upon acceleration it hesitates pretty bad but eventually goes. once your moving no problems. the plugs look old but gap is good cap+rotor needs some cleaning or just replace? I plan to do the fuel filter. from what I can see the vacuum lines seem ok. im going to clean the mass air flow sensor.. what else?
Old Oct 19, 2013 | 03:42 PM
redblzr4x4's Avatar
redblzr4x4 is on a distinguished road
mine was doing the same thing...i also changed plugs, wires, icm. still had the problem. took the MAF apart and cleaned it, and it worked fine again..
Old Oct 21, 2013 | 10:40 AM
after I did all that and put it all back together it seems like its running a tad high idle and my mph gauge is on the other side at 100mph. and rpm was alittle jumpy before now it seems even more sluggish. what is the idle suppose to be on how many rpms?
Old Oct 21, 2013 | 08:55 PM
Jordan40's Avatar
Jordan40 is on a distinguished road
Idle should be about 850 to 900.
Old Oct 21, 2013 | 09:16 PM
mine was there and then settle down to about 600 now seems to be normal cause that's what my jeeps basically are
jimspahr@msn.com
Oct 21, 2013 08:58 AM
DAVEHILLIKER
14
Jun 8, 2011 07:59 AM
robbi_carter
Jul 13, 2010 05:20 PM
robbi_carter
Apr 30, 2010 10:15 AM
O_P_PLaya
Headers, Intake, & Exhaust
Jul 3, 2006 06:14 AM
