2000 Chevy Blazer 4x4 no fire
Old Dec 22, 2010 | 04:02 PM
jameshannahjames's Avatar
jameshannahjames is on a distinguished road
then I grounded the wire and it cooked the fuse and ideas
well when i ran a new ground it cooked the fuse
put another fuse in it cooked it too something making ground?
Last edited by swartlkk; Dec 22, 2010 at 04:46 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 22, 2010 | 04:37 PM
Which wire did you ground?
And please wait for responses.
Old Dec 22, 2010 | 04:48 PM
Default re
k sry I grounded the white or it looks white and with a black stripe
Old Dec 22, 2010 | 04:50 PM
Only the black wire at the ICM (pin C) should be grounded. The white wire is the electronic spark timing control from the PCM and the white with black tracer is the ignition coil driver to the coil. Grounding either of which would surely blow the fuse.
Old Dec 22, 2010 | 04:59 PM
Default re
lol k duh my fault im gonna stay in for the rest of the night ill check it tommorow.
Old Dec 23, 2010 | 08:02 AM
Dave455's Avatar
Dave455 is on a distinguished road
I found the solution to my problem. It was the ignition starter switch. There is a dielectric grease in the switch that shrunk when it got colder and made it difficult to start. The part was under $75 and I had someone with the right tool to pull the steering wheel install it for $200. I was able to pinpoint the problem by letting the vehicle get cold enough not to start. Then use a hair dryer to warm up different parts until I found it was the ignition starter switch. I hope this helps anyone with a similar problem
Old Dec 23, 2010 | 10:05 AM
Tinted's Avatar
Tinted is on a distinguished road
iginition starter switch is where the key goes, right?
Old Dec 24, 2010 | 07:42 AM
Dave455's Avatar
That is actually called the ignition. The key turns a gear that turns another gear in the ignition starter switch. they connect together but are two seperate parts so you dont need to change your key to fix this problem.The ignition starter switch has the contacts for run start and acc. it comes with the wires attached that run down the steering column and a attach to the firewall.The multifunction switch (turn signal wiper, cruise etc) is also connected to the firewall at the same terminal block but have a removable clip.It took a good three hours plus to change this out but that also included a trip to the parts store.
Old Dec 24, 2010 | 08:18 AM
The proper term is ignition switch. Take a look at the Anatomy of the Ignition Switch link in my signature. Also, there are how-to's posted in the Tech Article (DIY) Index link also found in my signature.
Old Feb 20, 2011 | 07:02 AM
problem resloved thank you it was the wireing harness on the fuel pump bad wires
