2000 Chevy Blazer Question
Old Nov 20, 2012 | 09:48 PM
thundergod66's Avatar
thundergod66 is on a distinguished road
Default 2000 Chevy Blazer Question
I have a 2000 chevy blazer 4.3L,2-Wheel Drive and was wondering am i the only one who has this intake part with one nipple..(see pic).Lemme start from beginning,when i bought this blazer my heater only blows from the vents turning the **** from vent to defroster has no effect.After i searched i found a vacumm line comming from the T that came from fender and was just hanging there and what i found from here and searches that it goes to that part on the intake,Mine only has the big vacullum on top but not the smaller one on the side and it doesnt look like it been broken off..Is it me or does everyone have the two nipple one.Hope you all can help me on this one,my local junkyard is over 100 miles,wanna make sure first before i go look for one...
**look at the pic what im dealing with,have the top nipple but not side one,your help be appericated**
Old Nov 20, 2012 | 10:09 PM
Single nipple would be for 2WD without A/C. The vertical nipple goes to the PCV valve. If you have 4WD and or A/C, you need the double nipple. Try a local GM dealer or install a vacuum Tee in the PCV vacuum line: Buy Dorman - Autograde Hard Vacuum Tubing Tee 1/8 or 1/4 or 3/8 Inch 47349 at Advance Auto Parts
Old Nov 20, 2012 | 10:23 PM
mine is a 2WD with AC,maybe my motor has been replaced.I did find some numbers on the front of the head when i replaced my water pump,the num were in orange like the kind used in junk yards..The second nipple would affect my air from vent to defrost right?? I did try GM and all they had was the single nipple,do i need to tell them its for a 4wh drive instead of 2wh drive as in mine,,
Old Nov 20, 2012 | 10:30 PM
Yup, motor has probably been changed by a rookie The larger, vertical nipple, is for the PCV valve. The smaller one is for 4WD/HVAC.
Old Nov 22, 2012 | 10:12 PM
would the hvac control the air from the vents to the defrost,cause when i trurn the **** it only blows thro the vents regardless if i switch it to vent or defrost or to the floor??
Old Nov 25, 2012 | 07:42 PM
Yes, the vacuum line that's missing controls the HVAC actuators in the dash.
Old Nov 25, 2012 | 09:46 PM
i just reread my last post and asked the wrong question..what i meant to say is the vacumm pod on the intake with the second nipple control my air comming from vents and defrost and so on...And thanx for all ya help Captain Hook,ya really helped out big time...
konfettix13
Sep 22, 2013 01:47 PM
CPLSeraphim
May 7, 2013 02:40 PM
srtnation
Mar 10, 2011 05:15 PM
smitty1244
Tires and Wheels
Dec 5, 2009 01:52 PM
smitty1244
Nov 1, 2009 02:05 PM
