2000 Chevy blazer vent switching problem
Maybe someone could help. When I get on the throttle whether to pass someone or coming up a hill, my heat goes from the floor the the dash vents until i let off. Any ideas? Thanks
The heater box in your blazer uses vacum to control the mode doors. so if you had a vacum leak the mode door wil go to default and blow out the defrost. but it sounds like it works fine until your on the throttle. when you lay on the throttle to pass someone the engine does not have enough vacum to control the mode door. so it relies on a vacum resivor, witch holds vacum during heavy assceleration. so it sound like the resivor it not hooked up or missing. that was kinda how it was explained to me before. the vacum resivor on my 1997 blazer is mounted to the hood on the drivers side. hope this helps
trishharris
14
May 30, 2011 12:25 PM
waterskier98
Mar 4, 2009 03:15 PM
14Blazer88
Feb 6, 2009 11:54 AM
