2000 Heater switch stuck in defrost
Old Dec 12, 2009 | 08:26 PM
KC-BodyMan's Avatar
KC-BodyMan is on a distinguished road
Angry 2000 Heater switch stuck in defrost
Hey i got a 2000 s-10 blazer 4x4 4.3 with a heat problem. I seems the heat is comming out of only the defrost. I have checked vacuum lines under hood and behind dashboard and found no problem. I had glanced underneath around the transmission but saw no problem with the lines.I read there may be a switch on the tranny where 3 or 4 vacuum lines connect and can get oil in them that will cause the vacuum system to go into fault mode. That switch and the actual heat selection switch is the only things i can think of. Any got any ideas. Thanks.
Old Dec 12, 2009 | 08:53 PM
When you checked the vacuum lines at the HVAC control module, did you find any transmission fluid? And was there adequate engine vacuum on the supply line to the HVAC control module?
Old Dec 12, 2009 | 09:12 PM
KC-BodyMan's Avatar
I never found the exact location of the module, i found 3 or 4 lines running on the top of the tranny and i just went out and pulled one line off of a "Y" junction and tranny fluid poured out.I do belive theese are all vacuum lines.Do you know the exact where abouts of the module?And do i need to replace all the lines with fluid in them and the module or just the module?Thanks man.
Old Dec 12, 2009 | 09:22 PM
Ok... If you found transmission fluid there, then the vacuum switch on the transfer case has gone bad. You likely also have a failed input seal on the transfer case. Pull the fill plug on the transfer case. If transmission fluid pours out, you need to pull the t-case and replace the input seal.
Now, if you haven't pulled the vacuum lines off of the HVAC control module under the dash, then you should do that fairly quickly to see if transmission fluid is there as well.
MJKH84
Feb 22, 2015 07:02 PM
tleed
Feb 27, 2013 11:36 PM
gwkelly3
Aug 29, 2012 12:08 PM
90TBI
Nov 18, 2010 07:35 PM
samjsmith23
Aug 17, 2007 10:51 AM
