Heater fuse blows when put to defrost
Old Nov 14, 2010 | 07:35 PM
90TBI's Avatar
90TBI is on a distinguished road
Default Heater fuse blows when put to defrost
Hey guys I;m having a problem with my defrost setting on the Blazer. It works fine on the heater setting, but when i engage the defrost setting it blows the fuse. The blower motor is brand new so i know that it is not drawing too much amprage. I was wondering if anyone has had the same problem or if anyone has any suggestions.
Thanks a lot
Old Nov 14, 2010 | 07:53 PM
From your username, it would appear that you have a '90 K5. I assume that you also have A/C. There may be a short in the wiring to the evaporator pressure control switch and/or the wiring from the evaporator pressure control switch to the A/C compressor clutch. When in defrost, the A/C compressor will run to help pull moisture out of the air for faster defrosting of the windshield.
Old Nov 18, 2010 | 03:47 PM
90TBI's Avatar
thanks alot it was the conection point between the compressor and the lead.
Old Nov 18, 2010 | 07:35 PM
Glad you found it and glad to have helped!
mcmastrman
Jul 26, 2012 06:27 PM
taloka
Aug 17, 2009 03:12 AM
peanutblaze
Feb 17, 2008 06:07 PM
rdhack
Feb 9, 2008 10:32 PM
kammino
Nov 27, 2006 11:35 PM
