2000 jimmy bogs under load
Old Aug 28, 2010 | 05:35 PM
2000jimmbo4x4's Avatar
2000jimmbo4x4 is on a distinguished road
Default 2000 jimmy bogs under load
vehicle: 2000 jimmy 4x4.
problem: under load when cold,( lessens up when warm but still happens more frequently), engine bogs under acceleration past half throttle. if i baby it, all is well, revs up good with no load. has new tune up , airfilter, oil change, fuel pump, and fuel filter and lines. has no codes, no check engine light, no history codes either. any ideas? watched live data on scanner. o2s 1 and 2 bounce between rich and lean at idle then stay lean when accelerating. not quite sure what this means but it also seemed to show misses on cyl# 6.
Old Aug 28, 2010 | 08:45 PM
Have you cleaned the MAF sensor?
Old Aug 28, 2010 | 11:05 PM
AJBert's Avatar
Sounds like it could be your cat on it's way out.
Old Aug 29, 2010 | 01:23 PM
No, i havn,t cleaned the MAF. Do you have a voltage reading on what it should be around?. Whats the best for cleaning it? ive used CRC's MAF cleaner before and i really didnt see any change, on a difernt vehicle. How would i check to see if the cat. is going bad?
Old Aug 29, 2010 | 03:08 PM
MAF sensor output is a frequency that corresponds to the airflow going into the engine. You really cannot test it without some more specialized tools/equipment. Check out the Tech Article (DIY) section for a how-to.
As far as the cat goes, you could remove one of the pre-cat o2 sensors and drive it. If it accelerates better, your cat is restricting flow.
4x4life
Feb 20, 2013 12:16 PM
Ryan Cornforth
16
Feb 19, 2013 01:55 PM
atvwarrior
Sep 21, 2011 06:40 AM
etowntom
Sep 7, 2010 08:16 PM
EricTrembath
Jan 19, 2009 04:49 PM
