2000 jimmy wont start help please help
Old Jan 5, 2014 | 05:36 AM
Good job. Pressure below 60psi will cause the symptoms you described. Pressures should be 60psi to 66psi with the pump running, and remain above 55psi for at least 10 minutes after the pump shuts off. Both parts of the test failed. Most likely, the pump is bad. To find out for sure, you'll need to modify the tester so it will connect directly to the fuel filter outlet. All fuel pressure and flow must end at the tester.
Old Jan 10, 2014 | 06:23 PM
welderman85's Avatar
welderman85 is on a distinguished road
checked it at the filter and no good so I swaped out the pump. it runs great now thank you for all the help
Old Jan 10, 2014 | 10:06 PM
Cool, thanks for posting back! What pressure did you get at the filter with the pump running?
JimmyBlaze541
May 2, 2013 10:00 AM
birdmomma
May 10, 2010 03:03 PM
1992S10blazer4.3
Jan 29, 2010 08:35 PM
jimmy979
Oct 11, 2009 06:28 PM
scottyk
Mar 14, 2007 09:54 PM
