1992 s10 blazer wont start help please
Old Jan 24, 2010 | 07:08 PM
1992S10blazer4.3's Avatar
1992S10blazer4.3 is on a distinguished road
Default 1992 s10 blazer wont start help please
1992 s10 blazer wont start replaced alternator, plugs, plug wires, distributor cap, rotor, battery, and put a new starter in it and it wont start it will crank over but just wont start need help its my first car and dont want to dumb a bunch of money in to it. The fuel pump works it turns on and hums and you can here it while you are cranking it over, also pushed down on schrader valve and gas came out i dont know what the problem is please help! thanks
Old Jan 24, 2010 | 07:16 PM
ohsofly's Avatar
Does it have spark? Just changing the plugs and cap and rotor doesnt mean it sparked to begin with...? Pull off a plug wire, stick a screwdriver into it, and put it near some steel in your engine bay while someone else cranks it. Just make sure you are touching the handle not the metal shaft or you are going to have a hard time making a fist that day... You will see the spark jumping from the screwdriver to the metal.
Welcome to my world, Ive got about 500 bucks in new and used stuff into a blazer I drove home last week, and we cant get it to start now. It died on me and I had to tow it home half a mile the other day. Before that it was stalling and having no throttle response occasionaly, but was drivable. I have no engine codes, no strange lights...? Im baffled.
Old Jan 25, 2010 | 01:41 PM
it is has spark and just replaced the rotor, cap plugs and wires and it is getting spark from coil and the plugs
Old Jan 25, 2010 | 09:27 PM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
well i will say this from expirence, it sounds ALOT like the spider is bad, inside the intake its not cheap, and i wouldnt just take the black thing off and check for puddles of gas, because mine actually stopped working, it didnt leak just wouldnt pump the gas, pepboys has them for $250 you can put one in and give it a try, if it dont work just return it.
Old Jan 27, 2010 | 01:24 AM
ohsofly's Avatar
I would try a used spider first though. I got one at the parts yard for 10 bucks. Cleaned it up, and keeping it for a spare in case its needed. The new one sold for 800 bucks at Lordco...
Old Jan 29, 2010 | 08:35 PM
I had got another motor so hopfully the spiders are good or im going to drop it in
kmclaugh84
Apr 9, 2014 08:42 PM
randrm
Sep 6, 2011 08:53 PM
xgiovannix12
17
Nov 1, 2010 02:53 PM
riel Veil
Jul 16, 2010 10:47 AM
dcblazer
Nov 20, 2006 10:22 AM
