2000 ls blazer 4x4 problem?
Old Nov 3, 2011 | 01:53 PM
RobD's Avatar
RobD is on a distinguished road
Default 2000 ls blazer 4x4 problem?
Having trouble with shifting from 2HI to 4HI.Ive runnout and checked,most vacuum lines,actuator under battery,no problems with wiring routes or damaged wiring.I havent checked TCCM and its terminals or plugin,plugin and switch on T-CASE,and vacuum lines hookup behind distributor.When in 2HI,I push selection switch 4HI on the fly,and the tranny neutals out,there is no noise,nothing.When sitting still,Im in 2HI,I push selection switch to 4HI,tranny in neutral,selection switch flashes like its changing to 4hi,wait till it stops,put tranny into gear,tranny is in neutral,nothing???I get out to check the front driveshaft,it is free and not engaged,so to drive the truck it has to be selected back to 2HI.I do have 4LO and it goes in and out. and works fine.This truck is cherry and been kept very good care of,it has had the tranny rebuilt about 4 years ago,and works great!t has a 233C T-CASE. Is this a common problem with this truck? ANY TECH HELP OR ADVICE WOULD BE GREATLY APPRECIATED!!!!! RobD owner of S10'S for 11 years and counting!!!!!
Old Nov 3, 2011 | 05:38 PM
Mike98Blazer's Avatar
I think the transfer case is neutraling out, not the trans...... with that said have you checked https://blazerforum.com/forum/tech-a...2hi-4hi-40695/ to see if it's your encoder motor by chance?
Old Nov 3, 2011 | 08:20 PM
RobD's Avatar
no I havent,and I appreciate your imput!
Old Nov 3, 2011 | 09:06 PM
You're welcome. Post back after diagnosing and let us know what you find/don't find.
Old Nov 4, 2011 | 10:09 AM
RobD's Avatar
Thanks,Ill Do.
Kimosabe
Aug 29, 2010 04:23 PM
blazer2000ls
Jun 5, 2010 07:31 PM
laff31
Dec 30, 2009 04:55 PM
razman
Feb 22, 2009 01:57 PM
el8232
Nov 22, 2008 04:27 PM
