2000 lt blazer 4x4 4.3
Old Jun 20, 2009 | 09:47 AM
co112lt's Avatar
co112lt is on a distinguished road
Default 2000 lt blazer 4x4 4.3
i have fuel at the presure neddle check valve . but no fuel in the celenders . could i may be missed a wire plug in under the in
jector cover ? i pulled a couple plugs and they were dry .
i poured a little fuel in the throught and turned it over and it started up and ran . till all that fuel burned up .
Old Jun 20, 2009 | 12:05 PM
The presence of fuel does not mean that it is at the appropriate fuel pressure. Test the pressure and let us know what the gauge reading is.
Old Jun 20, 2009 | 12:12 PM
co112lt's Avatar
What would you use to test it? Never done this before so I'm not sure what the procedure is. Fuel pump was replaced a little over a year ago, when the engine is turned on you can hear the pump turn on. YES I am aware it may not be shooting enough fuel out. Just letting you know what we do hear and what we dont. It will shoot fuel into the carb but doesnt' seem as if its getting to the injectors.
Old Jun 20, 2009 | 12:23 PM
A fuel pressure tester... Get yourself a fuel pressure tester and screw it onto the fuel pressure test port then put the key to the RUN position. Pressure should be ~60psi.
Old Jun 20, 2009 | 12:29 PM
co112lt's Avatar
Ok thanks.. I'll check with some buddies n see if they have one we can borrow. I think he's out checking the injectors now.. and all of the connections to see if he may have forgotten to plug in something.
As soon as I know results I'll get back to you..
Thank you for the suggestion.
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
Coastiedude
Jan 5, 2010 12:24 PM
razman
Feb 22, 2009 01:57 PM
Jetfixer
Dec 16, 2005 02:32 AM
