2000 No start
Old Mar 3, 2009 | 06:05 PM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Default 2000 No start
Wouldn't you know it, I stopped in to my Autozone today to pick up a part. I get back outside and attempt to start my Blazer up and it doesn't start. So I call my buddy up and he comes over and whacks the bottom of the fuel tank while I attempt to start it. Wouldn't you know, it started!
He use to work at a Chevy dealer and has seen this many times. He could get it to restart by whacking the bottom of the tank. So, almost $300 later, I walk back out of the same store with a new pump. Tomorrow morning, I'm going to work on this.
Anyone know of an easy way to drain the fuel tank prior to dropping it? I know on the Bonnevilles, you can disconnect the fuel line from the fuel rail, apply 12V to the test line and run the pump manually. Anything similar to the Blazers?
Old Mar 3, 2009 | 06:47 PM
If you can get the pump to run, you can pull the filter and then jumper across the relay to power the pump. Just make sure you have some way of turning it off as your container gets full. And remember, no sparks!
Old Mar 4, 2009 | 05:25 AM
W2JGA's Avatar
Thanks for the info Kyle! No sparks huh. Dang, you took all my fun away for today.
Old Mar 4, 2009 | 06:51 AM
I'm not one to take someones fun away... Spark on!!
Old Mar 4, 2009 | 01:07 PM
brcidd's Avatar
brcidd is an unknown quantity at this point
I pump it out - Jumping fuel pump relay- whack on the tank and using an old r-12 a/c refrigerant hoses-(same connection and threads and depressor) attached to the fuel pressure test port- I feed the other end into my truck's gas tank- so that I have plenty of room in the "container" for gas..Takes about 20 minutes to get over a half tank out...
Old Mar 4, 2009 | 01:38 PM
W2JGA's Avatar
Just finished putting the new one in. Broke one small strap, the little clip for the other strap and that was it. Went to dealer and they had the parts needed, around $15. About 3 hours start to finish.
Old Mar 4, 2009 | 02:34 PM
Good deal!!
Old Mar 4, 2009 | 06:04 PM
W2JGA's Avatar
Oh and I never drained the tank. 3/4 left in the tank.
coolasice
Dec 9, 2024 09:53 PM
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
fremontt
May 7, 2007 12:42 AM
westernbronco
Jan 23, 2007 02:16 PM
