2000 pass lock security
Old May 18, 2022 | 05:31 PM
2000blazls's Avatar
2000blazls is on a distinguished road
Default 2000 pass lock security
I have a 2000 blazer a rat ate through the wire harness and fried the computer. I got a wire harness and computer from the local pick and pull and need the steps to program my key into the computer
Old May 18, 2022 | 11:20 PM
GeorgeLG's Avatar
Here you go
George
Old May 18, 2022 | 11:27 PM
2000blazls's Avatar
Yeah so a little bit about the car every thing is new. Brand new distributor, new ignition coil and control module, new crankshaft position sensor, new cap rotor wires and plugs, and I got a brand new programed computer from orielly. That's when we found out the wire harness was damaged so we warranty out the computer got another programmed unit. Went to scrap yard and got a used harness and computer just in case. Both the new warranty replacement and used computer succuss on program the security key however I still have no spark out of the coil. Put a high lever scanner on the car and computer is seeing no rpm reference as engine is cranking
Old May 18, 2022 | 11:55 PM
GeorgeLG's Avatar
The passlock system defeats the fuel injectors not the ignition. Usually the truck starts for a few seconds, the fuel injectors are cut off and the truck stalls. If you have no spark that's a different problem.
Spark is CPK>VCM>ICM>coil>distr>wires>plugs. No coil spark can be power, grounds, wires, connectors, VCM, sensor, ICM, coil. You can either start at the coil and work backwards or the CPK forward. Another approach is to check power and grounds to the VCM, coil, ICM and CPK first. No rpm during cranking implies CPK, VCM or their respective powers/grounds/wires/connectors. Let me know if you want me to help you diagnose the point of failure.
George
Old May 18, 2022 | 11:58 PM
2000blazls's Avatar
Let's start with the crank sensor. How do I check that?
Old May 19, 2022 | 12:16 AM
GeorgeLG's Avatar
The best way is to watch the output signal during cranking with an oscilloscope. Do you have a scope?
If not then you can look for output pulses with a digital meter while turning the engine by hand and test power and ground at the sensor:
https://troubleshootmyvehicle.com/gm...crank-sensor-1
George
GS-Drew
Jun 4, 2021 02:27 PM
townie
Mar 14, 2015 09:31 PM
aksallday
Mar 8, 2013 12:32 PM
walleye seeker
Jan 23, 2012 05:53 PM
bmx4life218
Aug 2, 2010 07:30 PM
