2000 zr2 4.3 5spd misfire?? stumble???
ok guys new here and i'm saying thanks ahead of time.
ok here's the problem, had my blazer from new never had a problem until now. so far i have replaced the fuel filter, air filter, plugs ,wires and battery. now the truck starts fine , but when i get to the desired speed and try to hold it there the truck starts to buck on me like a missfire, but when i punch the gas she goes no problem as so as i settle her back down and try to hold a certain speed the bucking starts again. any thoughts??????????????????
Don't quote me on this, it's just an educated guess but it sounds like maybe a problem with your IAC valve (idle air control). You say it starts fine but does it idle ok? Maybe a vacuum leak. Check for a hissing sound under the hood and try to pin point it. Good luck.
ok here ya go guys unplugged the iat (intake air temp)sensor. and it went away totally. ordered a new 1 will take a couple days. cecl engine light came on after the 1st couple miles with out the sensor plugged in. drove it around today for awhile with no sudden surging or bucking. seems like i mat have found the culprit.
dharvey4651
Feb 11, 2015 11:14 PM
rrk03300
Nov 15, 2012 10:29 PM
david068513
13
Aug 14, 2012 09:47 AM
kgpace
Sep 2, 2009 11:12 AM
