2000 Zr2 blazer
Old Nov 9, 2018 | 08:57 PM
tnpete's Avatar
tnpete is on a distinguished road
Default 2000 Zr2 blazer
Anyone know how well these older Blazers have held up? Found one for sale, its got 200,000 + miles on the clock. I like the looks of the 2 door Blazers. Just looking for a 4x4 to pull the boat 12 miles to the river. And in case that few Inches of snow hits every few years. LOL
I think hes asking more then its worth. But it is clean, new tires and wheels. Nice looking older Blazer.
Old Nov 9, 2018 | 11:01 PM
As for towing a boat 12 miles, should not be a problem. I tow a sailboat (boat + trailer = 2,200 lbs) with my 1999. I did burn out the transmission because I was a fool and used overdrive on drives across Washington state from North Idaho to go sailing on Puget Sound, north of Seattle. This includes a mountain pass. There is also a local hill that climbs 1,700 feet in 6 miles.
With a rebuilt transmission, an transmission cooler and the proper technique (i.e. never use overdrive when towing), I am confident I'll get 60,000 miles out of it.
These are capable little trucks. They do have their quirks. People say you will go through front end components (ball joins and idler arms) more than most vehicles. They will leak from the remote oil cooler lines, the replacing of which seems like a right-of-passage for any serious Blazer owner. There is also some annoying things like the vacuum lines that supply the vacuum for the front axle engagement and HVAC system will rot. Those are an easy fix though. The heater cores are really hard to replace. This can be a problem if either the original Dexcool coolant was run with too much air in the system or mixed with the traditional green coolant. A brown sludge would develop. (The newer formulations of the coolants apparently can be mixed.)
All the above things are repairs doable by someone with a small garage and a regular set of tools.
The one thing from which a Blazer cannot recover is if the lower intake manifold gaskets fail and dump coolant into the lifter valley. This will ruin the bearings in an instant. As soon as I learned of this, I replaced the gaskets. It was annoying with all the parts I had to get out of the way to get to them, but was very doable.
As for 200,000, if it was maintained well, it still could be fine, especially if a rust-free example. However, people will report buying Blazers of about that vintage with more like 150,000 miles. My motor and truck (except for the transmission) have 135,000.
Hope this helps. I'm sure others will be chiming in too.
Oh, and there are two types of transfer cases: the "3-Button" and "4-Button". The 4-button ones have an "Auto-4wd" selection that allows the transfer case to go in and out of engagement as necessary which I find nice when driving on roads where the plows haven't been able to scrape away all the snow and ice.
Old Nov 9, 2018 | 11:32 PM
papajim's Avatar
papajim is on a distinguished road
I also have a 2000 ZR2 that has over 220,000 miles on it, I agree with the person above with the normal problems. All of my running gear is original, i have recently put a new water pump and dist on it, I did put a new valve body in the trans to solve harsh shifting and torque converter not locking up. Fairly easy job. Get the ZZR2 and enjoy
Old Nov 10, 2018 | 03:45 AM
GeorgeLG's Avatar
I have 210,000 on my 2002 and it’s still going strong. Definitely plan on doing the LIM gaskets. Mine cut loose and I did lose a little oil pressure even though I replaced them after only about 5 miles so I had some bearing wear.
George
Old Nov 10, 2018 | 08:25 AM
tnpete's Avatar
Thanks guy, going to look it over today. Its a Southern Blazer, so no rust is showing. Paint looks good in the picture's. I have rebuilt engine's.
Put the engine in my 99 F-150 4x4 a few years ago. Never again on one of those. It burned a month ago. So searching for something to drive around home again.
Daily Driver is a 2005 Chevy Kodiak C5500, and 1995 Kenworth T600.
Old Nov 12, 2018 | 12:58 PM
Carolyne Price's Avatar
Carolyne Price is on a distinguished road
Default 2001 Chvy ZR2 4X4
Just had spider injectors replaced at 256K. Went ahead and replaced lower intake gasket too. Gotta fix some familiar engine codes still but engine seems to be still hanging in there! Looking for the 4x4 reset sequence right now. Anyone?
Old Nov 14, 2018 | 07:51 PM
tnpete's Avatar
This one sold before I could get there. OOOh well no issue, will find something else.
Pete
Andy3od
Aug 26, 2019 04:36 AM
JimmyTT
Jan 7, 2019 11:46 AM
nomoresubies
Oct 16, 2018 08:33 PM
rhodelle
Aug 14, 2018 11:00 AM
kmartin
Jul 11, 2017 05:15 AM
