2001 to 2003 dash swap
Old Feb 12, 2019 | 08:58 PM
Blazin_Alexei's Avatar
Blazin_Alexei is on a distinguished road
Default 2001 to 2003 dash swap
Hey guys, first post here. I have a 2001 2wd 4 door LS blazer. My dash is falling apart and i need to do a heater core as well. I have a good condition 2003 4 door LS 4x4 dash assembly. Does anybody know if the 2003 dash will be a direct fit for my 2001? And if the 2001 BCM will work with the 2003 dash wire harness? I plan on using all my switches/gauge cluster/head unit from my 01. And from what i can tell both dash boards are the same in terms of wiring for the switches/etc looked all over and couldnt find an answer to my question so hopefully someone with experience can answer this. Thanks
Old Feb 13, 2019 | 09:52 AM
LesMyer's Avatar
2003 dash should fit fine in a 2001. If any doubts about the wiring, switch it too when both are out.
I can tell you that wiring can vary considerably, depending upon options and application - even within a single year. But if the wire colors in all the connectors are the same and the wires are in the same position, then I think you should be OK.
Old Feb 13, 2019 | 10:32 AM
eshaw's Avatar
The dash will definitely interchange. It's like LesMyer stated, if the wires are the same position and colors it should be a shoe in.
Old Feb 13, 2019 | 10:46 AM
Thanks for the replies guys, ill probably do the swap over spring break and let everyone know how it gos.
Old Feb 14, 2019 | 09:53 AM
jimspahr@msn.com's Avatar
Very interesting. I think this is a rare swap. Please let us know how it goes. I am sure a lot of readers would like to know. May I ask what is the advantage of your swap from a 2001 to a 2003? IOW, what are you gaining?
Old Feb 14, 2019 | 09:58 AM
Jimspahr not looking to gain anything from the swap other than having a dash thats in decent shape. Only swaping to the 03 because i already had it from my old blazer so it didn't cost me anything.
geep
Oct 20, 2013 01:44 PM
crusemm
Dec 7, 2011 04:34 PM
hmmurdock
Oct 18, 2011 04:41 PM
gordonltaghon
Sep 3, 2009 05:44 PM
Canadian_Blazer
Feb 23, 2005 03:19 AM
