2001 Blazer 4wd ABS light and a 4wd question.
Old Jun 18, 2018 | 05:17 PM
Scott Regier's Avatar
Scott Regier is on a distinguished road
Arrow 2001 Blazer 4wd ABS light and a 4wd question.
So, 2001 Blazer 4wd.
NOTE: I have not taken it in to get an OBC reading.
ABS light: ABS started to "malfunction" when turning sharp around a corner and breaking the ABS would engage especially if there was a bump as well. Now ABS light stays on and the ABS does not work. Used to have the break light warning light to on also, but not now. Will an ABS problem register on an OBD reading?
4wd question: 4 button display with AUTO 4wd. Put it in 4 HI or AUTO 4wd it does engage but the light continues to blink in either selection.
Old Jun 19, 2018 | 06:00 AM
Strangerock's Avatar
Strangerock is on a distinguished road
If you can get the codes read for the 4wd it will help your diagnostic, If you cant, check the vacuum system for the 4wd , check and clean the TCCM connection ....Do you hear the TCCM clicking and do you hear the encoder motor moving ?.
Old Jun 19, 2018 | 08:20 PM
Exclamation
Vacuum system works fine because, as stated, 4wd engages. Guess I will look at the TCCM.
Thanks
Old Jun 20, 2018 | 05:53 AM
Are you sure it is engaging ? , The flashing lights are usually a sign that it is not ....and if you have a bad TCCM or encoder it is doubtful that the system is working properly.
Blazeme
Jan 24, 2015 06:08 PM
beaumoi
Jan 27, 2011 11:04 PM
fahli
Nov 28, 2010 09:27 AM
JLeigh34
Jan 7, 2010 02:47 PM
ESKYMOPACK
Jun 20, 2009 07:16 PM
