2001 Blazer Air Conditioning Problem
Old Aug 10, 2010 | 12:37 PM
dannydblazer's Avatar
dannydblazer is on a distinguished road
Default 2001 Blazer Air Conditioning Problem
Took my 2dr, RW/dr 2001 Blazer LS, in for air conditioning recharge. However, the tech said in only took in less than a can of coolant and the air wouldn't get cold. Tech stated it appears that I have some sort of compressor problem. Any suggestions my blazer comrades?
Last edited by dannydblazer; Aug 15, 2010 at 06:43 AM. Reason: to be more accurate with the description of my blazer
Old Aug 11, 2010 | 01:32 PM
1998MSO's Avatar
1998MSO is on a distinguished road
What was the reason you took it in for a recharge? Was your A/c working at all?
These A/C systems don't hold very much r134a refridgerant, so what your tech says seems accurate.
Old Aug 13, 2010 | 02:43 PM
I took it in for a recharge because it would blow cool air and warm air. So I figured it was due for more refrigerant. Yes, my a/c had been working fine. Is there a solution to this sort of problem that I could try myself before having to pay the costs surrounding compressor repairs?
Old Aug 13, 2010 | 02:59 PM
If it has too high of a charge, it could be tripping out on the high pressure switch.
Old Aug 13, 2010 | 05:10 PM
helo's Avatar
helo is on a distinguished road
No offense, but that doesn't sound like a very good A/C tech. Did he use a set of proper gauges to see what the pressures are while the compressor is running?
One of your pressure switches may be stuck. You can safely jumper the electrical plugs to test the system (just don't run it like that continuously as a fix). High pressure switch is in back of the compressor and low pressure switch is by the low pressure charge port on the receiver/drier. Replacing the high side switch requires a tech to evacuate the system, replace the drier and orifice tube, vacuum the moisture, and charge system. I think the low side switch screws into a valve...
If there's a decent pressure difference while running, the compressor is fine. If there's no pressure difference with compressor running and system is charged, then yeah, you need a compressor and probably condenser & a/c hoses. If the difference is so big it trips out one of the pressure cutoffs, you might have a clogged orifice tube.
Might need to have a tech evacuate the system and replace the receiver/drier ($15-20) before vacuuming the system dry and adding fresh 1.8lbs of freon (I think that's the right amount, the tech should have reference documents). While the system is discharged, definitely replace the orifice tube ($2). If the orifice screen is littered with metal shavings, then you may need compressor+hoses+condenser.
Old Aug 14, 2010 | 09:21 AM
Surgin's Avatar
Surgin is on a distinguished road
Mine was cycling on and off causing a miss feeling while driving. It was the pressure switch on the back of the silver can (dont know the name). I replaced it and it works right all the time. Just something to note.
Justin
Old Aug 15, 2010 | 06:40 AM
To 1998MSO, Swartlkk, helo, and Surgin, Thanks for your input!
Old May 22, 2011 | 05:32 PM
russ9320's Avatar
russ9320 is on a distinguished road
Thanks for the posts. I was having air conditioning problems for about a year, then it eventually went out all together. I checked fuses and the relay. I was thinking I was going to have to replace the whole compressor. Then I saw the post about jumping the connections on the switches. The switch on the reserve tank is easy to switch. It has a peacock valve so not much freon will leak out. $11 fix.
Old May 23, 2011 | 09:48 AM
billbobagns's Avatar
billbobagns is on a distinguished road
helo is absolutely right. Do everything he suggests, especially the orifice tube. Also, replace all o-rings while you have it apart, and flush all hoses and coils to get trash out. Then, re-assemble, evacuate, charge, (two $10 cans 134A).
Casole6
Jun 30, 2012 07:42 PM
akustom57
Jun 4, 2010 07:18 AM
littleblueblazer
May 24, 2009 04:14 PM
DrThorsen
Apr 14, 2008 10:46 AM
myboo11009
Aug 22, 2006 04:21 PM
