2001 blazer crank's but wont start
Old Mar 20, 2011 | 01:32 PM
Low voltage isn't good for the ignition system, but it shouldn't cause no spark at all unless the voltage is really low.
I would take the battery out and get it tested if you can.
Old Mar 20, 2011 | 01:38 PM
rogersblazer's Avatar
rogersblazer is on a distinguished road
Unhappy
i'll take it to get tested tomorrow,kinda stuck at home with no vehicle right now if i buy a new battery and i still dont have any spark, what should i try next? already replaced the ICM and coil.
o.k. now that it quit raining......the coil is sending spark to the distributor, but it isn't getting to the plug's....cam positioning sensor? hopefully some one will check out this thread and get back to me.
Old Mar 20, 2011 | 09:07 PM
ffox's Avatar
ffox is on a distinguished road
I think the most likely cause now would be the rotor or distributor cap. Check and make sure the contacts are not burned, and that nothing is cracked or broken..If you have enough battery power to crank the engine it's plenty enough to give you a spark.
Old May 12, 2011 | 11:26 PM
waviaerith's Avatar
waviaerith is on a distinguished road
Are there any new updates? Was your problem fixed? How did you fix it? I'm having an extremely simular problem and I'm at a loss for what to do!
Old May 13, 2011 | 12:50 AM
nonblazing4x4's Avatar
nonblazing4x4 is an unknown quantity at this point
I had the same thing happen to me. Turns out i busted the gear on the distributor. I has happen to me twice. After the second time I bought a brand new distributor and put in it and i didnt make it a block away from the shop and it was running terrable. Shop said that breaking that gear so much messed up my cam shaft. alot to replace. So i took it home and with a sawzal and a hammer i had the cat cut off and it was running great. It turns out it was so clogged that i guess it was building up so much back pressure it was putting a stain on the motor.
Old May 13, 2011 | 05:22 PM
you was right, it ended up just being the cap and rotor, i should have known to start with the simple stuff....DOHHH.
Old May 16, 2011 | 02:38 AM
rickka4456's Avatar
rickka4456 is on a distinguished road
i had this problem last week and i replaced the timing chain and water pump. worked!!
Old May 16, 2011 | 08:26 AM
GunsOfNavarone's Avatar
GunsOfNavarone is on a distinguished road
" i was on my way home the other day.. on the high way doing about 70mph . it just all of a sudden died i pulled it to the shoulder and tried to re-start it but all it would do is roll over but not fire..so i had it towed home . i know these thing's are famouse for fuel pump's going out so that was the first thing i checked.... "
Ignition switch is what I would replace. What you experienced is what many have had happen. There are many write-ups on ignition switch failure. A battery problem often won't be an issue when the engine is running. Intermittent igntion switch failures often act like a fuel pump failure
Spend the $70 for a AC/Delco switch and the two hours of labor. You likely will be glad you did.
Buddykitchen
Dec 10, 2016 06:37 PM
robwatson
May 22, 2013 05:40 PM
94_Jimmy
Jun 16, 2011 12:37 PM
Crazyfingers85
Feb 26, 2011 06:55 PM
NWI_Blazer
Nov 7, 2010 11:26 PM
