2001 Blazer Grinding at low speeds
Old Jan 20, 2014 | 05:36 PM
PhantomBlazer's Avatar
PhantomBlazer is on a distinguished road
Default 2001 Blazer Grinding at low speeds
Now that it is actually running again , I have rediscovered the other issue I had noticed. While traveling at slow speeds, about 8-15 mph, I heard a dry grinding noise coming from the rear end. At first I thought it was the brakes, but it does it even while I'm not braking. Any suggestions? Is it a major issue that would make it dangerous to drive about 30-35 miles tomorrow in the big snow storm we are supposed to get?
Old Jan 20, 2014 | 05:40 PM
Brake backing plates love to rot out on these things, might be dragging on the rotor.
Old Jan 20, 2014 | 06:10 PM
Did I read correctly somewhere that the axle needs to come off to replace?
Old Jan 20, 2014 | 06:21 PM
Yup, to do the job correctly, both axles have to come out to replace the backing plates. There are two piece backing plates available, and the axles do not have to be removed to install them. Kind of a rinky-dink set up, but I suppose they wrok.
Old Feb 5, 2014 | 02:29 PM
mwbrown4's Avatar
mwbrown4 is on a distinguished road
I had the same problem. I just cut mine out but i don't recomened it. I would do it the proper way if i was you. I would have but just don't have the time.
Clay_Assassin
Dec 12, 2010 08:04 PM
k5009
Jul 19, 2010 12:34 AM
3D_Illustrator
Jun 26, 2008 12:43 PM
JustinF01
Oct 24, 2007 12:50 PM
XtremeYellowChvy
Nov 15, 2005 03:01 AM
