Stumbles at low speeds when cold
Old Oct 23, 2007 | 07:54 PM
JustinF01's Avatar
JustinF01 is an unknown quantity at this point
Default Stumbles at low speeds when cold
When my problem started, it only happened when the Blazer was cold and usually only durring the first start of the day. It would stumble at low speeds (5-20mph) like I was hitting the gas and then stomping the brakes in rapid succession.
After a while it got worse and started doing it all the time. I changed the O2 sensors, MAF unit, fuel filter, and checked every fuse, wire, connector, and vaccuum hose.
This seemed to clear it up for a while but it just started to do it again very slightly like when it started originally. Any Ideas?
97 Blazer LT 4x4
4.3L, Automatic
Old Oct 23, 2007 | 08:22 PM
Default RE: Stumbles at low speeds when cold
When was the last time that you did a full tune up? Plugs, wires, cap and rotor?
Does it do this more when it is damp outside? If it does, then this could indicate a fouled cap as the more humid air allows the spark to scatter more when it jumps from the rotor to the terminal in the cap before travelling down the wire to the plug.
Old Oct 23, 2007 | 09:04 PM
JustinF01's Avatar
I think it was about 2 years ago I did the tune up on it. I changed everything.
It did do it more when it was damp. I'll check the cap once I figure out my major electrical problem...something is shorting out and wires are starting to burn. And every light and buzzer in the truck goes crazy when I try and start it.
Old Oct 24, 2007 | 12:50 PM
Hanr3's Avatar
besides the tune up, including a new fuel filter I would check out the cat too. A partially plugged cat will cuase too much restriction for low rpms, while higher rpms can still push past the restriction.
PhantomBlazer
Feb 5, 2014 02:29 PM
Clay_Assassin
Dec 12, 2010 08:04 PM
3D_Illustrator
Jun 26, 2008 12:43 PM
hotbloodsx3
Apr 2, 2007 07:08 AM
XtremeYellowChvy
Nov 15, 2005 03:01 AM
