2001 Blazer lifter adjustment
Old Feb 15, 2010 | 02:44 PM
brians1bad72's Avatar
brians1bad72 is an unknown quantity at this point
Default 2001 Blazer lifter adjustment
What is the method of adjusting the lifters on a 4.3l Vortec ? Thanks
Old Feb 15, 2010 | 03:32 PM
Torque the retaining bolts to 22ftlbs. There is no adjustment.
Old Feb 15, 2010 | 03:36 PM
Rottidog's Avatar
Do you have that "lifter clatter" too? I've had that from day 1 & have heard the 4.3 vortecs are known for it.
Old Feb 15, 2010 | 04:42 PM
Thanks for the info. going out to the garage to set them right now. Ya, I had noisy lifters the intake gasket was bad, I am replacing head gaskets, lifters and intake gaskets. Found anti-freeze in number 1 and 5 cylinder. I just replaced the intake gaskets and had the same lifter noise as before, thats why I am doing all the rest to eliminate the top end, the cam checked out ok. Also I plan on keeping the truck for awhile.
Old Feb 16, 2010 | 08:49 AM
Update on my Blazer, finished up with all the work late last night and the truck runs great no more lifter noise, I did get an air pocket in the system during refilling of the rad. but worked it out the truck runs great, thanks to all for the help.
Old Feb 16, 2010 | 09:23 AM
aleking's Avatar
aleking is on a distinguished road
say what you want about oil additives but I put lucas oil additive in both my blazer 94 k miles and suburban 120k miles and there is no noise what so ever quiet they have ever been
Old Feb 16, 2010 | 12:19 PM
Were did that come from, nothing to do with post.
Old Feb 17, 2010 | 04:21 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
I use Sea Foam in my crank and made the lifters go quiet for awhile, now the nosie is back, I say, crap its been this way for 100K and nothing has blown. So I will leave it alone. Plus I all of a sudden develope leaks after putting the sea foam in. Its about time to change the oil. Hopefully some of leaks will stop.
Old Feb 17, 2010 | 03:27 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
I've never used seafoam in the crank. You probably develop leaks because it cleans the dirt and gunk keeping that leak filled in. I only use Lucas in the oil. Always have.
NOs
Sep 1, 2016 12:09 PM
michigan_engineering
Jun 10, 2009 01:06 PM
spld2
Nov 4, 2008 10:03 AM
spld2
Nov 2, 2008 08:19 PM
glenmoore670
Feb 15, 2006 11:08 PM
